Chevrolet Avalanche Silverado Dual LED Pod Light Install Guide
Introduction: Chevrolet Avalanche Silverado Dual LED Pod Light Install Guide
About: Everything about automotive LED lights
This guide will teach you how to install iJDMTOY's high powered CREE dual LED fog light kit for the 2002-2006 Chevrolet Avalanche, 2003-2006 Silverado 1500, and 2003-2007 Silverado 2500 and 3500. Use these pairs of LED pod lights to directly replace your stock fog lights and enhance your Chevy's look and color output.
Step 1: Preassemble the U-shaped Brackets to the LED Pod Lights.
Use our step by step guide to help you put the LED pod lamps together with the U-brackets.
Step 2: Mount the Metal Bracket Plate to the Twin LED Pod Lights.
Run the bolts upwards from below the U-bracket so you have an easier time securing the connection with nuts.
Please note that the metal bracket plate you see in these pictures are from a test fit and will not be in the color you will get in your package. Your metal bracket plate will be colored for aesthetics.
Step 3: Remove the Stock Bezel and Fog Lamp.
Use a 10mm wrench to unfasten the screws securing the stock plastic bezel. Disconnect the stock harness from the factory fog lights. Remove the factory fog lights as well as the stock plastic bezel.
As you can see, the metal bracket plate has similar dimensions to the plastic bezel which makes for simple, direct replacement.
Step 4: Mount the LED Pod Lamp Assembly.
Adjust the angles of the twin LED pod lamps to ensure they shine through the gap.
Step 5: Connect the Wires to the Stock Harness.
You can do this by tapping the wires or using adapters. Repeat steps 1-5 for the other side.
Step 6: Test the LED Pod Lights to Make Sure They Light Up.
Once they do, you can now enjoy your Chevy Avalanche or Silverado's brand new LED pod lights!
Shop for more offroad truck LED lighting at iJDMTOY.com today!
Be the First to Share
    • Game Design: Student Design Challenge
    • For the Home Contest
    • Make It Bridge
      Make It Bridge
