Introduction: Chicken Feeder
This is our first instructable so we will start by showing you how to build a chicken feeder that will feed 4-6 chickens and remain free of droppings that chickens so often leave behind.
We have alot of that at our farm.
So lets get started!
Our animals can be seen by visting the link below
Barn Yard Life
Barn Yard Life
Step 1: Intro
Sure you can go the feed store and buy a feeder made from plastic or galvanized metal. Some of these are cheap and will last many years since they are not environmentally friendly. Lets face it; we all know how long plastic takes to decompose. Not to mention, plastic and sunshine are not the best combination either. I have bought a few plastic water feeders and none have lasted more than 2 seasons. So I started thinking of ways to keep the chickens safe and not pollute the environment. You are now reading the results of one those grand ideas. Its a fun project and should only take 30-45 minutes. Have fun and be careful.
Step 2: Materials
1= 1 x 2 x 6 board (NOT pressure treated)
1= 1 x 6 x 8 board (NOT pressure treated)
1= 1 x 4 x 8 board (NOT pressure treated)
Circular saw
Carpenters square or Speed square
30= 2 exterior grade screws
Drill with a #2 phillips head driver
A pencil
Tape measure
Table saw (optional: if you have a table saw you will not need to buy the 1 x 2)
Saw horses or solid work bench
Safety glasses (You only get one pair of eyeballs!)
Circular saw
A pencil
Tape measure
Step 3: Materials Dicussion
First, we need to discuss the materials. As mentioned next to the board, do not buy pressure treated lumber. Chickens are curious by nature and will peck at the wood. The chemicals used in pressure treated lumber are most definitely not a good source of food for your poultry.
You can get the lumber at any hardware store, or if you are lucky enough to have a local sawmill, get your wood from them. Lumber purchased at local sawmills is generally sized the exact dimensions you order.
Lumber from your hardware store is commercially sized and is smaller in dimensions than what you pay for. Either way, the results will be work just fine.
Next, you will need to pick up 30 screws to keep the chicken feeder intact. These can be purchased at any hardware store. I do recommend that you use an exterior grade screw, but a typical drywall screw will also work. At the size specified ( 2) you will get about 99 screws to a pound.
Step 4: Cutting the Pieces
Finally, we are ready to build our chicken feeder.
The feeder consists of:
2 side walls (1 x 4) cut to 12 in length
1 base piece (1 x 6)cut to 12 in length
2 end caps (1 x 6 ) cut to 6 in length
1 handle ( 1 x 2) cut to 12 in length (needs to ripped to 2 wide if not purchasing a 1 x 2 board)
Start by measuring the first sidewall piece to 12. Using the carpenters square, make a straight line. Make sure you cut the first piece on the outside of the line you drew so the 12 in length. The outside will be on the long side of the board.
Great, now just repeat that process 2 more times and you will have both side walls and the base. Be sure you only measure and cut one at a time or you will have different lengths of wood.
Step 5: Measuring End Caps
Now for the end caps, measure back 6 draw your straight line and cut on the outside again. Repeat this one more time and you have both end caps. While we are working on the end caps, lets measure and cut a 45 degree angle to clean up the edges.
Start at the top of the board and measure in 2. Make a mark at the top of the board at 2 line. Then repeat this process on the other side of the board so that you have two marks on the top edge of the board, both at 2 from the outside edge.
Now place your square with the angle edge facing the top of the board and slide it up until the edge of the square is touching the 2 mark you just made. Draw a line down the edge of the square. Then flip the square to the other side and do it again.
Using the circular saw, cut the two lines you just drew. Then repeat the whole process on the second end cap.
The final cut is the handle. Using the 1 x 2 x 6, cut off a piece 12 long making the cut on the outside edge. Be sure to cut on the outside of the line so the board will be 12 in length.
Step 6: Adding End Caps
Its time to put all those puzzle pieces together. Lets start by placing both side panels on the table with the short edge facing up. Now place the base piece on top and line up the edges, outside to outside.
Using 4 screws/nails, start at one end and screw/nail the base into the sidewall, working your way to the opposite end. Be sure to keep the edges even. Repeat these steps on the other side until the base is secured to both sidewall pieces.
Step 7:
On a flat surface, place the assembled base and sidewalls, base down. Take one end cap and place it against the base with the angles on top. Line up the edges and secure the end to the base using 3 screws/nails per side and 3 screws/nails along the bottom. Repeat this process on the other end.
Step 8: End Caps
Take the assembled piece and stand it on one end. Now place the handle between the two end caps and line it up between the two angled cuts you made. It should be flush with the outside edge or what will be the top when placed flat. Use 2 screws on each end screwing them thru the end cap into the handle. Try not to get to close to the outside edges or you will split the wood.
