Introduction: Child´s Chair Renewed
Take old and rusted chairs and turn into brand new! This is a pretty easy instructable. I´m posting to inspire you to do something similar! Hope to be helpful.
+ We´ll go through 3 easy steps:
1) Cleaning n´ Rust Sanding ;
2) Primer and Painting ;
3) Contact Adhesive Applying
+ Materials and Tools:
For Step 1: Wet towel, Sanding paper (i used 180 and 200 grain)
For Step 2) Primer and Paint, choose your color (as these are iron chairs I used a Enamel Paint)
For Step 3) Contact Adhesive Paper (Search at Amazon, Walmart http://www.walmart.com/search/?query=contact%20pap...
Let´s do it!
Step 1: Cleaning N´ Rust Sanding ;
Clean it up! Take off all the dust with a wet towel.
Start sanding the rusted areas, using first the lower grain sanding paper. You also have to sand the scratched areas.
Once it´s done its time to apply the Primer!
Step 2: Primer and Painting ;
I applied both the primer and paint with the roller paint, you can also use a painting brush or spray paint!
Step 3: Contact Adhesive Applying
First, the surface you are applying the adhesive must be clean.
Make sure to cut a size that fits good at the surface.
You can cut the edges with a snap-off blalde, and sand it at the end.
That´s all!
It´s pretty simple
Before and After Contest 2016
Living Without Closets Contest
6 years ago
Those turned out great and that was a nifty idea to use the contact paper :)
