Introduction: Chocolate Pumpkins
In this Instructable I'll teach you how to make quick and easy modeling chocolate, you can use this recipe to make almost anything you like, in the past I have done small figurines, roses and just general decorations for cakes.
Step 1: Chocolate Pumpkins
Ingredient and Supplies needed:
White chocolate
Corn syrup or golden syrup
Red/pink and Yellow food coloring
Green icing
Bowl
Food storage bag or cling film
Small pan or microwave
Toothpick
Step 2: Measure Out Ingredients
Brake the chocolate up as much as you can and measure out a 4 to 1 chocolate to golden syrup ratio.
Put in the bowl and gently melt until it all comes together, you can either use a bowl on a small pan of simmering water or microwave slowly, making sure to stir.
Mix until it comes away from the sides and resembles a dough like texture.
Step 3: Add the Food Coloring and Knead
Place in the food bag and knead together adding the food coloring bit by bit until you get the color you want.
Knead it well until it's soft and pliable.
Let it rest for 15 minutes or so before continuing.
Step 4: Roll Into Balls
Start by taking a small amount and rolling it in the palm of your hands until you get a smooth ball, then squish slightly to get a slight pumpkin shape, then using the toothpick slowly press from the top to the bottom of the ball going along to look like a pumpkin.
Step 5: Finish It Off
Finish it off by putting some green icing on the top.
I found that if you do three small blobs that it'll look more pumpkinny.
And your done, enjoy your creations, you can also use the modeling chocolate to make pretty much anything you like. I'll probably make something similar for Christmas treats too!
