Introduction: Chocolate Tin Recycled Into Planter With Hidden Storage
About: I enjoy repurposing and restoring old furniture and making woodwork projects that are not seen every day. I make most of my projects using wood that is either, recycled,reclaimed and love to repurpose and rest…
My idea for this project was to make a fun planter from a recycled chocolate tin. I am really hopeless with watering plants and thanks to my destructive dogs I can not have nice planters in my garden. So my idea was to have an indoor planter with artificial succulents. Because the plants would not need watering, I got the idea to add a secret storage compartment inside the planter.
While I have no use for a planter with a secret compartment, I am sure there are some teenagers out there that would love this idea. I remember having a secret hiding place for my diary and cigarettes as a kid. But it can also be hung on a patio with a spare house key.
Step 1: Find a Suitable Tin
For my Planter, I used a recycled quality street chocolate tin. You can use just about any tin, I liked this tin because of the shape. To cut an opening I used a knife to add a hole and used these cutters to cut the tin. I only cut away a gap around the top.
You will end up with some sharp edges which you can fold back using pliers.
Step 2: Decorate the Tin
You can decorate your tin to suit your decor. If you want to duplicate mine, here is how I made it. I recently made a project where I embossed aluminium soda cans into wall art. The effect was so cool I wanted to see if I could emboss faux leather to cover this planter. I started by adding so cardboard to both sides of the tin to smooth out the surface.
Step 3: ​Embossing the Faux Leather
The embossing machine I used is just a cheap and cheerful one that I bought secondhand from Facebook. I have bought a few different embossing folders since my last project which I used in this project. It is as simple as putting the faux leather in the folder and putting it between the plates. The plates are then fed through the machine.
I embossed enough leather to cover the back in the brick design. The leather was attached to the cardboard using “The ultimate” glue. This is my go-to glue for all my mixed media projects.
Step 4: Cover the Sides
To cover the sides of the planter I used thick brown paper which I embossed with a cobblestone design.
If you follow my blog you will know that I am steampunk mad. I was so determined to stay away from steampunk for this planter but I still ended up with steampunk elements to it. The faux leather on the front was embossed with some steampunk designs. To tidy up the edges I used some split conduit from my husbands’ toolbox.
I cut it in half again and glued it around the rim using hot glue.
Step 5: Making the Embellishments
I make all my own embellishments using moulds and resin. My favourite brand of moulds is the stamperia range because they have the nicest steampunk range. These moulds are all part of that range. I generally use regular resin but I wanted this to be a quick project so I used the UV resin that dries in minutes. You will need a UV light if you buy this resin. I use the UV light from my gel nail kit. I used hot glue to attach the resin mould.
If you still have any gaps you can fill them or paint over them. It does look a mess now, but with mixed media art, you have to try and ignore that for now.
Step 6: ​Painting the Planter
You can paint everything black using gesso or black acrylic paint. To make all the detail stick out I used some copper wax paste. To apply the wax paste you touch the surface of the wax with your finger and rub the wax across the raised surface of your planter.
I was not happy with the look so I added some more embellishments to the front and the back. You just need to paint it black and start again if you are not happy. My original idea was just to have the copper wax colour, but I felt it looked boring so I added a couple of other colours
Step 7: Adding More Colour
To apply the paint you can use a small makeup sponge and dip the tip into the paint and randomly dab some colour all over the planter. The colours I used is Art alchemy emerald green and deep waters which is blue.
Step 8: Adding Straps
The straps for this project were taken from an old handbag that I had at home. I would usually go to thrift stores or charity shops and buy a cheap one if I did not have one. The straps were screwed in at the top with a stud and the rest was glued using hot glue. I also added some copper wax to the straps so they blended in with the planter.
Step 9: How to Insert the Succulents
You can use the foam they use for flower arranging to go inside the planter. I did not have any so I use some old styrofoam packaging. If you want to add the secret storage you only need enough to cover the top gap that you cut out.
I used an old butter knife that was heated up on the stove, the knife literally cuts the styrofoam-like butter. I would not recommend using a good knife because it could damage your knife like this one.
The rest of the gap will become the secret compartment. You can paint the styrofoam black for a better cosmetic look. Once the paint is dry you glue the styrofoam inside the tin and put the planter back together.
Step 10: Adding the Succulent
I used fake succulents for this project so I did not have to look after the planter. You can arrange the succulents by pushing them into the styrofoam, you can also use some hot glue if needed.
Step 11: Lining the Base
You can add some fabric or paper inside the planter to make the secret compartment look more appealing. This faux planter with secret storage can be hung on your porch or just sit in plain sight in your home.
Step 12: More Unique Project Ideas
Step 13:
How to make a barn quilt table
Lots of great unique DIY ideas can be found on my website Unique Creations by Anita.
