Introduction: Choux Au Craquelin (Homemade Cream Puffs)
Today I’ll show you how to make a true French classic – cream puffs with a crisp craquelin topping and a smooth, creamy filling. This light, airy dessert is simply irresistible!
These little buns, called choux in French, have a delicate shell that melts in your mouth, paired with a silky milk-based cream that adds a rich, comforting flavor. They look elegant and neat — perfect for both a festive table and a cozy evening treat.
This recipe is great for confident beginners and anyone wanting to master choux pastry. Just follow the steps carefully and pay attention to the details — the results will be worth it!
P.s. You can see the same step-by-step recipe with more photos and video on my website yumchief.com or YouTube channel. I'd be happy if you check it out and leave a like and comment! It will help me a lot, thank you! ❤️
Ingredients
For the craquelin:
- Butter — 33 g
- Sugar — 40 g
- Flour — 40 g
For the choux pastry:
- Butter — 60 g
- Water — 62 ml
- Milk — 62 ml
- High-protein flour (11–13 g protein per 100 g) — 70 g
- Eggs — 3 pcs
For the cream filling:
- Egg yolk — 2 pcs
- Sugar — 40 g
- Flour — 20 g
- Milk — 200 ml
- Cream 35% — 170 ml
- Powdered sugar — 15 g
Step 1:
Making the craquelin:
Start by making the craquelin – a thin layer of dough that forms the signature cracked topping.
In a bowl, mix 33 g of softened butter with 40 g of sugar until smooth. Add 40 g of flour and knead into a soft dough.
Step 2:
Place the dough on one half of a sheet of parchment paper, then fold the other half over it. Fold the edges to form a rectangle.
Step 3:
Fold the baking sheet in half and cover the dough with one half of the sheet. Then, fold the edges of the sheet to form a rectangle.
Step 4:
Roll the dough out to about 2–3 mm thick. Transfer it (still in the parchment) onto a board and freeze for 15 minutes.
Step 5:
Once firm, cut out small circles (about the size of your buns – I used a 4 cm shot glass). Gather scraps, re-roll, and cut more if needed.
Keep the craquelin discs in the freezer until you're ready to bake.
Step 6:
Making the choux pastry:
Crack 3 room-temperature eggs into a bowl, beat with a fork, and set aside (don’t refrigerate them).
Step 7:
In a small saucepan, combine 62 ml of water, 62 ml of milk, and 60 g of butter. Heat gently until the butter melts.
Turn up the heat, bring to a boil, let it bubble for 10 seconds, then remove from heat.
Step 8:
Sift in 70 g of high-protein flour (gluten is key here). Mix with a spatula until smooth and lump-free.
Step 9:
Once the flour absorbs all the liquid, return the pan to the stove on medium-low heat. Cook for 1–1.5 minutes, stirring constantly, until the dough is smooth and silky.
Step 10:
Transfer the dough to a bowl, spread it out, and let it cool for 1–2 minutes.
Step 11:
Gradually mix in the beaten eggs, adding them in 4–5 parts. Mix well after each addition. You're aiming for a thick, stretchy puree. You might not need all the eggs.
Step 12:
When the dough flows off the spatula in a wide ribbon forming a “V” shape, it’s ready.
Step 13:
Transfer it to a piping bag. Preheat the oven to 210 °C (410 °F).
Step 14:
Baking the buns:
On a parchment-lined baking sheet, use a cookie cutter to dust outlines with flour, leaving 4–5 cm between each.
Step 15:
Pipe choux dough onto the marked spots. Place a frozen craquelin disc on top of each and gently press down.
Step 16:
Bake at 210 °C for 10 minutes, then reduce to 180 °C and bake another 12–15 minutes until golden.
Let the pastries cool completely — they should be crispy outside, soft inside.
Step 17:
Making the custard:
For a light, butter-free cream: whisk 2 egg yolks, 40 g of sugar, and 20 g of flour until pale yellow.
Step 18:
Heat 200 ml of milk to a boil, then slowly pour it into the yolk mixture, stirring constantly.
Step 19:
Return everything to the saucepan and cook over medium heat, stirring until thick. When it bubbles with large blops, it’s ready.
Step 20:
Transfer the custard to a shallow bowl, cover with plastic wrap touching the surface, and chill in the freezer for 15 minutes.
Step 21:
Meanwhile, whip 170 ml of heavy cream with 15 g of powdered sugar until soft peaks form.
Fold the chilled custard into the whipped cream. Transfer to a piping bag with a metal tip for easy filling.
Step 22:
Filling the buns:
Make a small hole in the bottom of each bun (I used a chopstick).
Pipe the cream into the buns, turning them slightly as you fill. For best results, fill them 1–2 hours before serving and chill — this helps the cream set and softens the buns.
Step 23:
Your delicate choux buns with creamy filling are ready. Enjoy!
