Introduction: Christmas Disco Ball
This is a quick project that really looks cool. This is a lighted ball that uses miniature christmas lights with multi function controller.
Step 1: You Need the Following Items.
You need the following items:
1 - Coat Hanger
50 - SOLO 9 oz. clear plastic cups
1 - 150 multi-color miniature christmas light set with multi-function controller.
1 - Soldering Iron.
1 - Coat Hanger
1 - Soldering Iron.
Step 2: Let's Make a Ball!
To start grab a couple of plastic cups and your soldering iron. Hold the cups next to each other and poke a hole with the soldering iron at the base of the cups and one at the top of the cups. Let it cool briefly and give it a squeeze with your fingers.
Step 3: Add Some More Cups
Now add a cup to each end of the first two.
Step 4: And Add Even More Cups
Now stack three more on each side of the group of four.
Step 5: Keep Adding Cups
Now just keep adding cups to make the ball when you get close to the top leave a few out so you can get your hand in side. Now at some point they won't fit exactly but don't worry about it if there are gaps just make it a ball it will look fine.
Step 6: Find the Center
Set the completed ball on a table and determine which cup is the bottom center cup and mark with an X. This is for the coat hanger to be installed last.
Step 7: Light Installation
Light installation. A few comments about the lights. Most of the 150 light string sets have 5 colors of lights but only a three channel controller. So what I do is buy a couple of strings and change all the bulbs so I have a three color sequence. I think it looks better but I have made them without doing this also. When installing the lights power them up so if one unplugs it shelf you will see and fix it before getting everything together.
To install the lights poke a hole with the soldering iron and quickly install the bulb. Make hole a little smaller than the diameter of the bulb so it's a friction fit. Install three lights per cup (50 cups X 3 = 150 Lights).
Start at the cup marked with the X and keep adding lights cork screw fasion until you get to the top.
Step 8: Add the Hanger
Once you get all the lights installed cut the coat hanger and shape one end to fit in the bottom the cup you marked with an X.
Step 9: Finish Up
Poke a hole to fit the hanger through and slide through. I usually put a few zip ties to center everything up.
That's it I hope it brings as much joy as it has for our family.
