Introduction: Christmas Treat - Rice Krispies House!!
This week I decided to make this Christmas treat and film the process so you can also make it!
For this recipe you will need:
Rice krispies
Marshmallows
Butter
In large saucepan melt 3 tablespoons of butter at low heat. I didn't have butter so I used hazelnut butter to add a different taste.
Add 40 regular marshmallows and stir until they are completely melted.
Remove from the heat and add between 5 and 6 cups of rice krispies (depending on the size of your cup) and Stir until they are all well coated.
Pour the mixture onto a glass pan previously coated with some cooking spray. Let it cool for about two hours or 30 minutes in the fridge.
Cut the edges and start cutting the pieces of the house. Cut a house shape and put it over the rest to cut two pieces of the same size.
To cut the side walls put the front part next to it so you can measure the same height, and cut a rectangle.
For the roof cut slightly bigger rectangles.
Then carefully build the house, as it is really sticky the pieces will easily stick to each other.
For decoration I melt some chocollate in the microwave and pour it into a plastic bag, then I use this to draw the tiles of the roof.
Use your imagination and use any sweet that you want to complete the house.
If some of the candy don't stick to the house melt a marshmellow in the microvave at low heat and use it as glue.
And that is it!! I hope you like this video and have fun making treats for Christmas!!!
Thanks for watching!! ^-^
Rice krispies
Marshmallows
Butter
