Introduction: Chute Board
Ordinary Skateboards Set
This skateboard is different from the traditional skateboard, mainly because its main panel design is different.
This skateboard in true proportion to the average skateboard: the actual value I measured is within plus or minus one centimeter. Length 81, width 20, height 4.5, thickness 1.2. The wheels are 5 in diameter, 2 in diameter, and 16 apart. (unit :cm) the following modeling USES Shift key for proportional adjustment.
Step 1:
Build slide wheel body. Form a T - row clip on one side of the wheel.
Step 2:
Use the combination of cylinder and landing platform.Combine the combined wheel, ladder platform and
cylinder to form the combination as shown in the figure
Step 3:
The connecting part between the wheel assembly and the main plate. Base it with a rectangular shape, place a cuboid on it, and then use two hollow cuboids that rotate clockwise for 30° to form the figure as shown in the figure.6. Use the inner semi-circular arc-shaped cuboid
to cut edges and corners .
Step 4:
Make plane switch and combine into the following figure
Step 5:
Use the figure to construct support body.Combine the support body with the previous
combination shape.
Step 6:
Build the skateboard body . Use cuboid and two elliptic cylinders.
Step 7:
Add QR code content as thinkeracd website.
Step 8:
Switch work plane to finish final combination.
Skateboard Contest
2 years ago
Interesting idea adding the QR code :)
