Introduction: Cinderella Pumpkin Mecha Carriage
cinderella carriage
1] a computer
2] tinkercad
Step 1: Making the Pumpkin
open the tinkercad 3d design space and under the shapes, the 'egg' should be selected ...then the egg should be rotated 90 degrees with the wider end facing the workspace...then duplicate the egg and rotate the new egg about 45 degrees east....then drag the new egg 10 clicks left and 5 clicks upward ....duplicate the egg 6 more times and this makes the egg into a pumpkin shape ....select all eggs and group as one...then change the colour
Step 2: MAKING THE WINDOWS
select a cylinder, make it length longer such that it will go through the pumpkin diagonally ....duplicate the cylinder and cross them diagonally into the pumpkin ....group the cylinders and change it from a solid object into a hole....then group the pumpkin and the the clyinders....and you will have the windows
Step 3: MAKING THE INTERIOR OF THE PUMPKING
Select a cylinder ...reduce it height and make the circumference bigger... insert the cylinder into the pumpkin and change if from a solid material into a hole....select both the cylinder and pumpkin and group as one object and there will be a chamber in the pumpkin
Step 4: MAKING THE ENTRANCE
Select the half cylinder....insert it partially into the side of the pumpkin between two windows...change it from a solid to a hole and group it together with the pumpkin...
Step 5: STAIRS
Select a box ....make it wide ..select another box and make it less wide and repeat with another box....stalk one over the other and group them together ...
Step 6: Frame Work
select select the bent pipe....rotate and drag it to place...select a cylinder and reduce it to the bent pipe size....group them, duplicate them and and moving them to the necessary place while also rotating them such that the cylinder always face away from the pumpkin.....then fit the tip with another bent pipe....select two boxes and make the width of one bigger then the other group it and place it between the two framework ,,,this is the driver's seat...
Step 7:
add cylinders to the bent pipe..... select the wheel...duplicate and put each in it place.......thanks
