Introduction: Circuit Board Lamp 2.0
This is a very simple, LED lamp made with old motherboards
Step 1: Items You Will Need
Led Lighting strip $6-$10
http://www.amazon.com/gp/product/B00HSF66JO/ref=s9...
12v adapter $10
http://www.amazon.com/Power-Adaptor-Transformers-S...
Old circuit boards from electronics
Free
Glue gun and sticks (about $5-$10)
Step 2: Cut the Circuit Boards to Your Needs
The size doesn't matter. Its really just what you want. I cut mine around PCI slots for effect.
Don't focus so much on what size, more of the items from board you want on your lamp.
Step 3: Glue Together!
I hot glued it. I am sure there are other techniques to bond these, but I went with hot glue
Step 4: Cap and Mount
I used a piece of blue foam I had laying around. Use wood or another piece of circuit board if you want. Just make sure you can mount the lights to it. I wrapped them around a 1x1 piece of wood. Easy to mount because the lights have a adhesive backing. Then I hot glued the wood wrapped in led light to the foam board top cap. I left bottom off for cord exit.
Step 5: Plug It In!
Enjoy your finished product. I spent around $10. Cause I had alot of the need items around the house.You can do different colors.
Check out my store https://www.etsy.com/shop/IzrailCircuitShop
