Introduction: Circuit With RGB LED
In this tutorial you will learn to make a RGB LED light up any color you want.
- Elegoo Uno R3 Microcontroller board
- Breadboard
- RGB LED
- Three 330 ohm resistors
- USB cable
Step 1: Attach the LED and Resistors
Attach the three resistors above the RGB LED as shown. Do not attach a resistor above the longest end of the LED because we will connect that to ground in the next step.
Step 2: Connect the Wires
To see which end of the LED corresponds to which color, see the above image. Then connect wires going from the top of each resistor to the input pins on the microcontroller board. I color coded my wires in the photo. Finally, connect one wire going from the longest end of the LED to GND.
Step 3: Write the Code
You will need to download Arduino IDE for this step: https://www.arduino.cc/en/software
You can find my code here: https://github.com/tejbho/ArduinoProjects/blob/main/RGBlight/RGBlight.ino
Step 4: Test the Circuit
The program will ask you which color you want the LED. In the video I change the LED to a variety of colors. See if you can make your own!
