Introduction: Circular Lifting Magnet
ELECTRO FLUX Circular Lifting Magnet can handle tones of scrap continuously throughout the day. It is used in metalworking plants to hoist and transport steel parts, forgings, casting, plates, booms, channels, angles, rods and bars. They save time and effort because they can lift steel more quickly and conveniently than any other mechanical device.
ELECTRO FLUX Scrap Lifting Magnets feature the highest lifting capacity. It can handle tonnes of scrap continuously throughout the day. It is used in metalworking plants to hoist and transport steel parts, forgings, casting, plates, booms, channels, angles, rods and bars.
They save time and effort because they can lift steel more quickly and conveniently than any other mechanical device. With a lifting magnet there is no need to attach and secure lifting supports and nor is it necessary to block up loads on the floor or to move for mechanical devices.
Applications
Applied to lifting and transporting magnet-conductive materials such as steels and irons in metallurgy industry ,mine industry,machinery industry and transportation industry and etc.
Features
Rugged-all-welded construction with good moisture-proofing strong attraction force and low energy consumption. The energizing coils are designed to improve the electrical property and mechanical property of the energizing coils. Heat-resistant grade of insulating material reaches Grade C with long service life. Simple and convenient installation,operation and maintenance.
MAGNET MODEL NO. SIZE OF MAGNET DIA. KW APPROXIMATE WEIGHT OF MAGNET KG.
LIFTING CAPACITY
HEAVY MELTING SCRAP PIG IRON STEEL TURNING SINGLE SOLID
EF CLM 1 650 2.5 600 KG 150 90 75 2500
EF CLM 2 1000 6 1.2 T 500 620 210 8000
EF CLM 3 1250 8 1.7 T 720 900 300 12000
EF CLM 4 1350 12 2.5 T 1000 1200 400 15000
EF CLM 5 1550 15 3.5 T 1400 1600 500 18000
EF CLM 6 1800 18 5 T 1800 2300 800 22000
ELECTRO FLUX Scrap Lifting Magnets TERMINAL BOX is designed to ensure protection whilst in operationand are of double entry type enabling the leads from the coils to be sealed in a separate cavity.
The outsidecable is brought through a gland into this second compartment ensuring no possibility of moisture entering the windings. MAGNETIZING COILS for magnet size up to 900 mm dia is pure annealed wire wound and above these are strip wound. The glass insulation of class H standard with Fibreglass NOMEX tape forming an interlayer makes coil withstand high temperature.
BUMPING PLATES are of high grade Manganese Steel Casting as per IS-276 with heavy ribs for added strength. These are clamped in position by the center and outer poles offering complete protection to the coil.
The magnets are suspended with three legged STRING CHAINS made of best quality forged steel terminating in a forged ring. A two core cable is provided for connection with the supply and suitable Insulated plug and socket ensure easy operation
Applications
Features
LIFTING CAPACITY
