Introduction: Circular Swing
I'm a student at HOWEST and our projects was to make a swing.
This is a tutorial to make the swing.
Step 1: Requisites
the requisites needed are
- +/-35m of robe 15mm
-+/-15m of robe 1mm
- 2 carabiners of 100mm
- 2 carabiners of 140mm
- 2 tennis balls
- sand
- 2 screws or nails
Step 2: The Tennis Balls : 1
first cut the tennis balls open for 5 cm
Step 3: The Tennis Balls : 2
then fill the ball for 1/2 with sand
Step 4: The Tennis Balls : 3
after filling the ball cut 5m of 1mm robe and tie it to screw or nail ,let 10 cm of extra robe at one side
do this 2 times
Step 5: The Tennis Balls : 4
afterwards put the screw or nail in the ball and fill it up with sand
when the ball is almost full take some silicone and put it al over the sand
do this for both tennis balls
Step 6: The Tennis Balls : 5
close the ball and the thie the robe around the ball so it is tightly closed
now you have your trowing weights
Step 7: The Robes
The robes for the swing are easy to make cut 2 times 10m of robe
at one end of both robes you make a knot like the first picture and attach the 100mm carbiner
at the other end you make a strop and attach the carabiner of 140mm ,to this carabiner you also attach the robe of the trowing weights
Step 8: The Swing
take 14.5m of robe and make 8 circles of 180 cm outline
at the begining of the weaving you take a small piece of 1mm robe and thai both ends together
than you start weaving through your 8 circles and close together for 50cm than you thai the weaving robe to the outher robe of the 8 cirles and cut of the excess
take than 25 cm of open space on the cirkels and make than a new patch of 50 cm and your seat is finished
Step 9: Hanging in Tree
Step 10: Hanging in Tree
trow the tennis balls over a branch
pull them down and hook the 140mm carabiners around his own robe and pull them around the branch
hook the 100mm carabiners around the swing
with a easy knot adjust the hight
of the excess robe make a ball
the swing hangs !!!
Step 11: Taking It Down
undo the 100mm carabiner and hang the swing around yourself
undo the not for the hight
take down as in movie
roll everything up and attach to swing
