Clap Switch
Intro: Clap Switch
Hello Friends,
Here is a clap switch. You can turn any home appliance on/off with a clap. I personally designed the circuit for better accuracy and customized filtration. You can see the working of the switch in the video attached.
I hope you will enjoy building this project.
STEP 1: Circuit Explanation
The signal processing done in the circuit is explained in the image.
There are 4 stages of the signal procesing:
- In first step, the input from the mic is anplified.
- In second step the comparator is used to put a threshold value on the amplified value, to be considered as a clap or not.
- In third step the pulse from the comparator is converted into a longer pulse, this is helpful to reduce the noise in the clap.
- In fourth step, the signal is first used to turn on the LED, and next time it turn the LED off. This is done using a decade counter and resetting the counter on the Q2. Q0 is left blank, Q1 is the led/relay attached to.
Q0,Q1,Q2 are the outputs of the decade counters. if you see the datasheet of 4017. First time clock is given to 4017, it gives output on Q0, on next clock, output shifts to Q1, and so on.
POT1 = used for the voltage for the microphone
POT2 = used for initial biasing for the transistor
POT3 = used to set the reference voltage for the comparator
STEP 2: Building the Circuit
Things you will need to build the circuit :
- potentiometer - 100K,20kX2
- LEDs X3
- BC547 X2
- 12v RElay
- diode
- resistors 160k, 470X3, 1k, 22k.
- Condenser MIC
- LM358
- NE555
- CD4017
- Switch
- 12v Adapter/batter
- Prefboard/dotted PCB
- IC base - 2x8pin, 1x16pin
- 100nF capacitor (104)
- 10uF capacitor (any voltage)
You can build the PCB in many ways :
The best way is the one in which i made it. You dont need to spend money or time on preparing designs and PCB print for the circuit.,
or you can build it on breadboard,
or you can design your own PCB and solder the components on it.
Happy soldering :)
I hope you will enjoy building the project, any suggestions or questions are most welcomed.
STEP 3: Calibration of the Potentiometers
To calibrate the device, the first step would be that you should use lowest voltage LED available to you, in the place of LED1. This is because the low voltage LEDs glow at lower voltage consumption and you will be easily able to identify the glow when you make a clap sound near the mic. (i dont remember my blue LED's voltage consumption but its very low, may be lower than even 1 volt, you can try using small LEDs).
Second thing you need to keep in mind is that you need to set POT2 such that initially the LED1 (low voltage LED) must be off. It must be fine calibration. Its Not hard to do so. The thing is that initially we need to give nearly 0.7 volts at the base of the first transistor. and we can do it by adjusting POT2. POT1 is easy to calibrate. First set the POT2 such that LED1 is off, then make a clap near the mic and notice the glow of the LED1. NOW, Change the POT1 value, set the POT2 again such that LED1 is off, then make a clap and notice the glow of LED1. you will notice the difference in the glow of LED1. you have to set the POT1 and POT2 such that the glow is highest in lowest sound. (POT1 must be greater than 5 kilo ohms). Once you are done with the glowing of LED1, now you should go to LED2 with POT3. POT3 sets the reference voltage to be compared to the voltage after amplification from the transistor (LED1). here you can set the sensitivity of the device, that on how much volume should the switch work. the output can be seen on LED2. you will have better idea when you will adjust it a couple of times. one thing is that you should never calibrate the pots all at the same time, i.e. you should first change the value of one portion of the circuit and notice the change, then change the other part's calibration.
40 Comments
MatthewO95 5 years ago
I trying to make this clap switch, but can't quite seem to make it work. I've so far been able to get all the lights to light up at once initially, but during my attempt to calibrate LED 1, when I clap, LED 1 does a short flicker, which I can assume isn't supposed to happen. No matter how much I calibrate it, that is the most I can get out. Does anyone by chance know what might be causing this issue? Furthermore, how do I know when I'm ready to do calibrating rather than needing to fix a mistake? I know this comment is being made 2 years after the previous comment, but if possible, I would really like some help. Attached is an image of my current work on the clap switch, in a non-calibrated state. Thank you for reading.
Samartist 5 years ago
First thing is that i dont exactly remember how i calibrated the circuit, i had to read the article once again to have good idea about it... Actually it will help me if you upload a working video of your circuit instead of the image... anyways, see what i have got to say to you...
1. "when I clap, LED 1 does a short flicker, which I can assume isn't supposed to happen.", its good that you have a flicker at LED1, this means that your circuit works fine till LED1. Now next thing is caliberating LED2, which is very easy, you just tune it till the point where is stops glowing.... It should be off in ideal situation, but it should be at the peak to glow... For example, if the LED2 glows in 0' - 90' degree of the potentiometer (one quarter of a circle), and its off in 91' - 180' degree(next quarter), then you should tune it to 91' degree... i.e. closest point when the LED is off...
2. i think you should remove the relay, it doesnt help if the clap detection anyway, you can use it later when you want to on or off any appliance..
3. its better to make this circuit IC by IC from left to right, i.e. first make the transistor part on the board, then caliberate it, then add the LM358, then caliberate it and so on...
I'm doing fine. Thank you for responding back. I did some of your suggestions, and while LED 1 is dimmer than the other lights, I got the switch to work. Thank you so much for helping me out, despite it being 2 years since you made this. I hope you have a good day.
jwbrooks0 7 years ago
The original clapper design was a 2-clap system, and this appears to be a single clapper design. Is there an advantage of a 1-clap to 2-clap design?
Agustinus bruin 7 years ago
Samartist 7 years ago
ok, what are you trying to do? How did you get to know that 555 is not generating the signal? Show me pics of your circuit...
Jaseelt6 7 years ago
ĐứcS 7 years ago
Can you give me your design, please?
sorry, i cant give it to you...
haha its already in the instructable :D
NguyễnQ12 8 years ago
Where is Q0, Q1, Q2 ?
sorry about that,
rajesh dhusu 8 years ago
anooooos 8 years ago
dimasgomez 8 years ago
Samartist 8 years ago
sorry for replying late :
feel free to ask about any doubts. i may reply late, but i am happy to help.
Huntsman064 8 years ago
I may be 9, but that I think is cool! also I would be able to make that
just 'making' this circuit is not enough, i think you must make small circuits first, which are very basic circuits...
you should make the following very-simple-circuits first, and understand those workings and then it will be very easy for you to make circuits like clap switch...
1 - LDR + comparator circuit = darkness detector
2 - 555 led blink
3 - 555 +4017 chaser circuit
4 - darkness detector using transistors
5 - 555 as monostable
as a beginner you should build circuits on breadboard : enjoy making circuits
tijoecon 8 years ago
I noticed the 555 IC has two pin7 i think the one connected to 12V should be pin4 am i correct?
