Introduction: Class Computer Build
First things first, gather your materials and prepare your work station.
Step 1:
Once you have your motherboard out, insert the CPU and RAM very carefully so as not to damage the CPU pins.
Step 2:
When preparing to screw in the motherboard you will need to first find where the screw will go in the case.
Step 3:
After carefully inserting the RAM and CPU, attach the fan on top of the CPU, and insert the IOS shield after screwing in the motherboard inside the case
Step 4:
Once the motherboard and the fan are installed all that is left is to install the driver which is shown in the right of this picture.
Step 5:
Make sure that the driver that you are using is compatible with the case and will fit and not be loose or too tight.
Step 6:
Then all you do is seal up the case and you're done.
