Introduction: Classy Cylindrcal Paper Lamp
easy to make ,elegant, classy lamp.
Step 1:
Things you will need
-Construction paper (the color you want your lamp to be,i chose black)
-Tracing paper
-P.V.C glue
-Paper cutter
-Light fixture (for the base)
You can use this lamp as a small table lamp or a large floor lamp.
Step 2:
Cut the construction paper into a rectangle
if you want to make a floor lamp.you will have to make a larger rectangle, the length being the height of your lamp and the width being the base of your lamp( which will be formed into a circular base)
for a floor lamp you have to cut out a really large rectangle
for a table lamp you will need a small rectangle...an A4 size will do just fine
now, cut tracing paper of equal proprtions to the construction paper rectangle,and keep aside
Step 3: Step 3
Lay the construction paper on a hard surface and cut out any design you like.
Use templates if you like :)
Step 4:
After the design has been cut out on the construction paper, glue the tracing paper neatly behind the construction paper with the pvc glue. put aside to dry
Step 5:
gently shape your construction paper into a cylindrical shape by gluing the two lengths of the rectangle together.i start by stippling the two ends then slowly gluing them with a glue gun,the staples keep the cylinder stable (not open up)
Step 6: Last Step
all you have to do is fix the light fixture ( a bulb) below the lamp,and you are done :)
you can get a light fixture base made by your local carpenter,i usually make my own.
enjoy
