Introduction: Clay Crucible Recipes
This instructable is a few recipes for clay crucibles, getting them ready to melt metals and lots of pictures of things that didn’t quite work out for me. But hey, it was fun.
I have successfully melted Aluminum, Copper, Silver and various bits of mixed metals with these recipes.
Step 1: Recipe Number 1
Straight to it.
You’re going to need fire clay and silica sand.
300 grams silica sand.
200 grams fire clay.
Fire clay can be found at most places that sell concrete and cinder blocks. I got my fire clay and silica sand at BASALITE. They were really nice and the stuff is cheap.
A 50 pound bag of fire clay was $12.80 and a 100 pound bag of 70 mesh silica sand was $8.52 not bad huh!!!
You can make a lot of crucibles with that much material.
Mix the sand and clay together (dry).
Slowly mix in water until it holds its shape when squished in your hand. This took me some practice to get it just right.
Form the crucible using your favorite technique.
I used a mold.
Let your crucible dry.
Step 2: Cooking Recipe Number 1 Crucible
After your crucible has dried you will need to cook it before you use it.
This will help to burn off all the stuff in the clay that can contaminate the metal you may be melting and it will set the clay to make the crucible stronger.
I used a simple charcoal setup for this.
Get some charcoal, a chimney starter, a bit of dryer duct and a hair dryer to cook your crucible.
Place the charcoal in the bottom of the chimney starter.
Place the crucible in the middle of the chimney starter. Fill the rest of the chimney starter with charcoal. Place it on something so you can fit the dryer duct under it.
Start the coals.
Once they are glowing red hot you can put the dryer duct in place and start the hair dryer on low. Let it run until the coals have burned down about half way and add a few more on top.
Run the hair dryer for about an hour longer then let the whole thing cool in place over night.
If everything went well you should have a crucible that sounds kind of like a coffee cup when you flick it with your finger.
If it has any cracks it will fail if you use it. So don't use it.
Step 3: Recipe Number 2
You should be able to get all of these items at most pottery stores.
I picked mine up at Potters Center.
10 grams Alumina Oxide.
40 grams Feldspar.
75 grams Kyanite.
75 grams Kaolin clay.
75 grams Calcined Kaolin Clay.
300 grams Silica Sand.
Mix everything together dry.
Mix in water slowly until it just holds its shape when you squish it in your hand.
Step 4: Recipe Number 3
10 grams Aluma Oxide
40 grams Feldspar
75 grams Kyanite
75 grams Kaolin
Mix everything together (dry).
Step 5: Recipe Number 5
55 grams Feldspar
75 grams Kyanite
60 grams Kaolin
Step 6: Recipe Number 6
100 grams Kaolin
300 grams Kyanite
Step 7: Cooking Crucibles
I tried cooking recipe 2 and 3 with the charcoal method but found they didn’t get hot enough to develop much strength. The first time I tried using them they broke from the force of the Borax expanding inside of them.
This can be a bit annoying especially since it takes some time to get them ready.
So I changed the cooking of recipe 2 through 6 with extremely improved results. If you have access to a kiln you’re all set if not you can make one real quick with some fire bricks.
They need to be cooked in a kiln or some form of kiln to around 2300 degrees Ferenhight and held near that temperature for around 45 minutes to an hour. This may sound like a bit of a tough thing to do if you don’t have a kiln however it’s really not that bad.
Once they have cooled they will sound like a coffee cup when you flick it with your finger?
Now fire up your refractory.
Get your crucible a little warmed up before you put it into the refractory by placing it on some hot coals.
Melt the heck out of some metal !
So far my favorite recipe is number 6.
Clay crucibles can handle the heat but you do have to treat them a little different then a metal crucible.
Temperature shock is a problem for clay.
It seems to be pretty easy to address by simply setting the crucible on or in some hot coals after use so it can cool slowly.
If a crucible cracks you will want to stop using it.
You don’t want a crucible full of lava spilling all over you, do you?!?
Step 8: Lots of Cool Pictures
These are a bunch of extra pictures.
