Clay Pot Planter Without Clay
Intro: Clay Pot Planter Without Clay
Hai all,
In this Instructable, I will be showing you how to make a clay pot planter without using normally available clay. I always had a passion for indoor planting and I believe that using plastic pots may decrease the natural beauty of plants. So I planned to make a clay pot. But I was not having any clay with me and I felt that bricks may help me. And fortunately, it did! So now let's see how we can make such a beautiful clay pot using bricks.
STEP 1: Make Brick Powder
Rub the brick with a wire brush to make brick powder. Make sure that the brick powder contains only fine particles. If larger particles are present use a filter to separate it. Then transfer the powder to a bowl.
STEP 2: Add Water to the Powder
Add potable water to the clay powder and mix it thoroughly. Mix clay powder and water in a ratio of 3:1.
STEP 3: Shape the Clay
Make a ball shape out of the clay and start modeling by putting a depression on it. Afterward, increase the size of the cavity by pressing it with your fingers as shown in the figure. Use hand gloves if required.
STEP 4: Dry It
Dry the pot in the sunshine for an hour before firing it. Give a curved look to the bottom edge of the pot.
STEP 5: Fire the Pot
Prepare fire under a grill and place the pot on the grill to fire the clay pot. Make sure to fire both the top and bottom sides of the pot. Do the firing process for 15 minutes.
STEP 6: Inspect the Pot
Take out the pot and inspect for faults. Rub with water if you have found any cracks on the surface. Even though you haven't any faults, fire the pot for another 45 minutes. So a total of 1 hour of firing process is to be done.
STEP 7: Finishing Works
I have sanded the top of the pot to make it flat. This is optional. Then paint the pot to give it a nice look.
STEP 8: Place a Plant of Your Choice in the Pot
Since the pot is made of clay it will be the best for your plants and clay will help to provide cool surroundings for the plant. You can pour water to the plant without any worries of leakage. Give a fresh new natural look to your indoor plants by using these clay pots. Enjoy planting.
12 Comments
Matthew Yang 2 years ago
casualhobby 4 years ago
Vishnu robotechs 4 years ago
LeslieGeee 4 years ago
Feelunike 4 years ago
v4utech6 4 years ago
rocket radhi 4 years ago
