Introduction: Clean 4 Port NES USB 2.0 HUB on the Cheap
This instructable will show you how to make your own very clean looking 4 port usb NES controller.
I know this has been done before, but I'm posting this to show you how I did it because it ended up much cleaner.
Parts Cost = $4 for the USB Hub
The rest is free if you have it laying around.
Enjoy!
Step 1: Parts & Tools
Parts:
1 NES Controller
1 4 Port USB Hub This is the one that I used. It was less than $4.
Tools:
Small Screwdriver
Pliers
Hot glue gun
Hot Knife or Exact-o Knife & Lighter.
Step 2: Destruction!
Time to take apart that old NES controller and that brand new hub.
Cut that NES controller Wire. It's just in the way. Save it you may find something to do with it later.
Remove the screws from the back of the NES controller as well as the USB Hub.
Remove the screw from the circuit boards of both the controller and USB Hub. Toss the case or keep it for a later project. It does have a nice little USB holder on the back you may be able to reuse.
Now there is something wrong with the hub board so be GENTILE!
Step 3: FIX THAT BOARD!
The USB wires are just DANGLING... They're asking to be broken off. So get out that hot glue gun and glue them to the board.
This will prevent you from ripping them off of the PCB as easily.
Step 4: Modify the NES Controller
Now you need to modify the NES controller to fit the USB board.
I have circled all of the parts that I broke or cut off.
The straight piece on the top is optional. I didn't cut it, so you don't have to. If you're having trouble this may be your problem.
The top two screw holes I melted down on the OPPOSITE SIDE OF THE CONTROLLER (not the one in the pictures). Just make sure you keep checking the back so you don't melt through it. I later filled these melted holes in the back with black JB Weld.
Place the USB Board where you want it to be in the controller and mark where it needs to be cut.
I cut on the inside of these lines to make sure it was as flush as possible. Too small? Cut a little out with your exact-o knife.
TIP: If you find that cutting it with your exact-o knife is too hard try heating it up with a lighter. It should glide through it like butter. Just BE CAREFUL!
Keep cutting until it fits. DONT CUT TOO LOW! There is enough room to cut out and make the ports flush with the top of this half of the controller.
Pull out the select/start button and cut off the top half of the button so it looks like the picture below.
Once it fits in there run your wire around the two grip posts and out of the hole at the top.
I glued the board down with hot glue at this point to make sure the ports would stay flush.
BE GENEROUS! Use as much glue as it takes, just make sure it doesn't go above the board.
This also prevents movement from USB cables being plugged/unplugged.
Step 5: Assembly/Further Modification.
Now you're ready to put it all back together.
After doing this I found that the buttons seemed really loose. So I opened it back up and put a big dollop of hot glue behind the buttons on the rear side of the case. Worked like a charm!
Now just plug it in and test it out!
Hope you enjoyed this tutorial!
Thanks! Mike
NOTE: I have seen a mod on here that involved peeling the front sticker off and scraping the red paint off of the Nintendo Logo. If you're feeling adventurous you can do this and rewire the USB light right under the hollowed out nintendo logo. I think it would be pretty sweet, but just didn't feel like doing it. Maybe some other time!
6 Comments
7 years ago
good idea
13 years ago on Step 2
Quote: "be GENTILE" I am luckily.
14 years ago on Introduction
I would have soldered in a USB memory stick, that way you can have a USB hub and memory stick all in one.
14 years ago on Step 5
i did mines 1st but urs came out more cleaner den mines i like how ppl find new ways 2 reuse old gaming stuff i give u kudos 4 trying out my mod
The cord is kinda short, but if you have a NES hub you'd wanna show it off too right? :)
I have seen this done before & I like the idea very much. I think the cord is pretty short on this, and would have liked to see the original controller cable or something similar used (not necessarily the whole length). Maybe incorporating the USB connector into part of the controller plug...
