Introduction: Clean Mix
I got the idea to make something to help you bake, so when your mixing something things dont go everywhere when you mix. First, I got these materials to try out different things that could work with my idea.
Air Dry Clay, Water, Bowl and a Wooden stick.
Step 1: First Attempt
I used the bowl to shape the clay the way I wanted and make sure it was even. I put the line because the project I had in mind had two layers.
Step 2: Second Attempt
These are the second materials I chose, I decided to change my materials when the clay did not dry the way I expected it to. I got two plastic lids, glue and scissors which made my project the way I imagined it. Here I stacked both lids to see kind of what it would look like when it would be compleated.
Step 3: Final Product
This is the final product, I glued the two layers and cut holes on the lids to leave space to be able to mix comfortably.
Step 4: Display
This is the complete and final look of my product. I put it on the mixer to show hoy it would look when using it. It gives enough space to mix and it still covers enough of the mixer not to make a mess.
