Clean and Grease Your Skateboard Bearings
Intro: Clean and Grease Your Skateboard Bearings
It's winter out there. The streets are covered with water, salt, and funky road grit. But you really want to skate. What can you do? Answer: go skate anyway, then clean your bearings so they'll live to skate another day.
This is a straightforward demo of how to disassemble, clean, grease, and re-assemble a skateboard bearing. Just in case you wanted to see it done. It's actually terribly easy if you've done it once.
STEP 1: What You Need
Dirty skateboard bearings. (Can be obtained from within dirty skateboard wheels.)
Acetone or other solvent. (97% Isopropyl Alcohol is good too.)
A bowl or cup to put it in.
A small pin or straightened staple to remove the bearing shields.
STEP 2: Pop the Seals
There are two kinds of seals that are common on skateboard bearings: rubber seals (pictured) and metal shields.
The seals can be popped out from the other side with a small pin or straightened-out staple. Stick your pin between the ball cage and the outside bearing race and press the seal out. Aim for the center of the seal, because it is made of metal and you won't puncture it.
If you've got metal shields, they're held in place by a circlip around the outside edge. Get your pin under one edge of the circlip and it'll come off easily. Then the metal shield just pops out. See this website for pictures of how to get the clips off.
STEP 3: Soak and Clean
Fill up your bowl with 1/2" of acetone and put the bearings (balls down) in the solution and let them sit for a minute.
Alternately tap them on the bottom of the bowl and spin the bearings in your hand until they feel grit-free. Once you get a bearing cleaned, spin it dry and place it on a clean paper towel (balls down) to dry.
Repeat for the other 7 bearings.
While the bearings are finishing drying off, clean up the seals in the acetone. Be gentle -- you don't want to bend the inner metal ring.
STEP 4: Optional: Filter and Save Your Acetone
If you're cheap (or thrifty) you can filter the big grit out of the acetone and save it to use again.
If your coffee filters are like mine, it won't be perfect. But it'll be good enough to re-use a few times, or you can experiment with multiple filters. Store your used acetone in a well-marked (skull and crossbones are good) airtight jar wherever you keep your deadly chemicals.
STEP 5: Grease and Re-seal
Add grease to the little pockets in-between the balls. Most people use just enough to barely fill three pockets. More or less (by a little) is ok. You don't want them packed, but you want all the balls lubricated.
Bike grease is fine. Marine grease will work. Silicone or lithium grease? Sure. Molybdenum grease? Overkill, but if you've got some lying around the house, you can use it.
Spread the grease around with your finger and roll the bearing back and forth until you can see all the balls adequately covered.
Gently place the seal back on. It will "snap" into place. Then, since you completely un-lubed it, run your greasy finger around the outside of the rubber seal just enough to keep it moistened. Also get some grease on the metal surfaces to help keep the rust away.
Note at this stage you could be using an oil instead of a grease. Good oils are Bones Speed Cream, Tri-flow, and other similar lubricating oils. Motor oil will work too. Bad oils include WD-40 and 3-in-1 (too light). If you use oil, 2 drops are usually enough. Spread it around by spinning the bearing and re-assemble.
STEP 6: You're Done!
Congratulations. You've just cleaned and re-greased your skateboard bearings.
Grease is nice because it needs maintenance less often than oil. On the other hand, it probably spins a little slower. Still, a clean and lubed bearing spins much much better than a dirty one, so it's good for you in the long run.
Note that you can switch back to oil when it finally stops raining and all the darn salt is off the freaking roads....
How often should you do this? It depends on how much you ride, and how often in crappy conditions. For greased bearings, try once every month at first or more often if you're in the wet a lot.
Oiled bearings need maintenance every couple weeks if you ride every day. I tend to clean them out right after a rain ride -- the oil just doesn't provide as much rust protection.
105 Comments
Ora 15 years ago
Herionx 1 year ago
The Real Elliot 15 years ago
Ora 15 years ago
hawksP 6 years ago
swiss is ceramic so the balls dont rust. atleat i dont think...
LucasS3 8 years ago
adam.ozcelik 9 years ago
are the ripstik bearing supposed to be oily/greasy? i opened up my ripstik for the first time dont know if i should clean it or not
Herionx 1 year ago
JohnS1377 4 years ago
Gaigebunn 3 years ago
Herionx 1 year ago
eoo 3 years ago
Yousuf Nasir 3 years ago
Herionx 1 year ago
Herionx 1 year ago
ZackR16 7 years ago
I have a board I've had for awhile and kinda forgot it outside under my porch during the winter. It just started seizing up and I don't have any oil or acetone to use on it any other stuff I could use that work like stuff that's around the common household?
BeauxH 7 years ago
any citrus based cleaner works
Bike oil.
Jamin PaulS 8 years ago
is Organic all purpose cleaner ok instead of acetone?
organic all purpose cleaner has
plant nased surfactant,citrus extract,water
and i use to lubricate my bearings is sewing machine oil
