Cleaning Apple Aluminum Keyboard....or Any Other Soft-touch Keyboard
Intro: Cleaning Apple Aluminum Keyboard....or Any Other Soft-touch Keyboard
As clean as you or I might try to keep our aluminum apple keyboards, they become filthy after a year or so. This instructable is to help you clean it out. Be careful, because i am not responsible if your keyboard breaks while doing this....SUCKS FOR YOUUU lmfaoo...but seriously it's not that easy to break
STEP 1: Unplug
this may sound obvious...but it needs to be stated. If you do not unplug your keyboard, you may cause serious damage to it electronically....so be safe, not sorry. Also, try to get away from your computer, so you don't scratch your monitor (etc.); im only saying that because i'm clumsy and that sounds like something i would do. =]
STEP 2: Remove Keys
when snapping off the keys, it is crucial to be extremely careful. the attachments are in different directions, so pay attention. lift the key in the upper left corner until it snaps, then see which direction it is in. snap the other part off and make sure no pieces broke off. it cannot be explained...so start with the keys you use the least, so you can practice. after the second key, you'll be a pro. some bigger keys like the enter key or the spacebar have more than one connection and may have metal pins, so keep that in mind. just always remember to be careful
STEP 3: Clean Keys
with a medicine dropper, pour a liberal serving of rubbing alcohol onto a folded paper towel. rub the keys vigorously against it and the filthy grime will just pour off. the paper towel will get dirty and start to crumble, so change places occasionally
STEP 4: Replace Keys
replace most of the keys by firmly pushing them straight down. the keys with metal brackets have to have the metal brackets correctly inserted before you can push down. i had a little trouble with the f-keys, in which some of them were permanently depressed. for these keys, i just removed them and deliberately hooked the pins in first then pushed the snaps down.
STEP 5: Sparkly Clean
Done!! overall, i'm ecstatic about the results...my keyboard is crisp white once again. it took me about an hour and a half, but i did it while relaxed and could be done much faster
8 Comments
buckymarino 15 years ago
Hanzo 6 years ago
I was going to thank the OP for the good info on those pesky keys, but then you pointed out THE TRUTH!
askartist 14 years ago
voidref 12 years ago
Carefully remove the top and bottom metal bars (leave the center one in, it's just a stiffener.
Put the metal bars through the tiny metal eyelets, one up and one down, and leave them just barely in each, flat on the bottom.
Carefully seat the space bar, bottom side first (to catch the bottom clips, and then press the top and bottom of the keyboard until the metal bars and plastic tabs all seat themselves.
Good luck!
killerjackalope 15 years ago
itshurleytime 15 years ago
aliceownsj00 15 years ago
