Introduction: Clear Thinking
I thaught and Built.
This is how....
Step 1: Stay Concentrated & Practice It
1. Cut & Shapped this indoor Marien Plywood
2. Sheet of 3mm perspex for top,side,& front of PC
Step 2: Glueing Bracket to Main Plank
3. As one see's, i cut mini planks (top left)
4. Applying woodglue to the main plank i cut earlyer
5. Stuck Thick Wooden Strips to the Main Plank (Woodglue)
6. Cut out Base of PC
Step 3: HDD Brackets
6. board 10mm grooves into the Thick wooden strips (Mini Planks) or (HDD Bracket)
7. Screwed HDD Bracket to Base, with other steel brackets
8. Drilled Holes in the HDD Bracket for ventalation purposes
9. Board 10mm grooves into HDD brackets on main Plank
Step 4: Cutting the Perspex
Go to next step to see The PC taking a certain form (Shape)
Used a fine Thooted General use hand saw
Step 5: Taking Shape
Next, Cooling Fans...
Step 6: Cutting Perspex for Cooling Fans
Mark and Cutting Perspex for Cooling fan
I eventually borrowed a Hand Craft Drill set and cut along the red lines
Step 7: Cutting Rear of PC for Power Supply
Step 8: Mounting Power Supply
10. Messuring and Cutting for Power Supply Unit
11. Used a Jigsaw to cut a hole for power supply fan on main plank
12. Chiselling grooves for fan shield
13. I mount the pwer supply unit
Step 9: Mounting Mother Board
14. I cut a breadboard to the specifications of the M-Borad
15. Mounted the M-Board with rivets
16. I used velcro strips to mount M-Board to the main plank
Step 10: Camera Broke... (No Pictures of Other Progress)
Step 11: Here Is the Finished Project
17. Side
Side (a)
Side (b)
Side (c)
Side (d)
18. Front
Front (a)
19. .Rear
Rear (a)
Rear (b)
