Introduction: Climbing Cardboard Gorilla
This is a cardboard version of a traditional wooden toy, with a small modification to give it swinging legs, "just because".
Step 1: Materials and Tools.
- Corrugated card - enough to draw three copies of the template - maybe one and a half sheets of A4?
- plain paper for templates.
- Glue - I used PVA craft glue, but anything that sticks card will do the job.
- String - three or four metres of slightly-rough string. Not the hairy stuff, but slightly rough.
- A drinking straw.
- A cocktail stick or bamboo barbecue skewer.
- Cutting tools - scissors, craft knife etc. If your card is thick, you will need a large sharp knife like a Stanley knife (I believe Americans call them box-cutters?)
- A drill - it is far easier to drill through several layers of corrugated card than it is to poke a hole.
- A piercing tool - something to make a small hole in the card, such as a sharp pencil, a nail etc.
- Printer or drawing tools.
Step 2: The Gorilla Template
I hand-drew the original (see the scans), and you can do the same, or you can print off a copy of the scanned-and-drawn-over version I have attached as as a PDF. If you cannot see the full-size scans, don't worry. They are mainly an archive of the design process - the PDF file contains everything you need.
Notice that you need several layers of card - the torso and arms are made of three layers, the legs are one layer and the head is an added piece.
- I tilted the different layers of the torso at different angles compared to the ridges in the corrugated card. This made the finished model stronger than if all three layers were at the same angle.
Step 3: Construction (1)
Cut the various parts out of the card, and pierce a hole through the, er, delicate parts of the gorilla to hang the legs from, and a similar hole through the centre of the single leg-layer. The legs will swing better if the hole in them is slightly larger than the cocktail stick or skewer you use.
Step 4: Gluing.
Glue the three layers of the torso & arms together. Make sure the layer with the missing lower section, and the slots missing from the hands, is in the middle of the three layers, and that you have laid a cut piece of straw in the palm of the hand, in the slot missing from the middle layer.
Don't be mean with the glue - like a composite material, the glue provides a lot of the strength of the finished toy.
Depending on the type of glue you use, lay the torso pieces under a book for a suitable time (overnight for the PVA).
Step 5: Construction (2)
Glue the head onto the front of the torso, in an aesthetically-pleasing position.
- You will need to add features to the head - you can draw them directly onto the card, or onto the plain paper and then glue that onto the front of the head.
Step 6: Something to Climb.
With the remains of your corrugated card, make a simple beam, about as long as the distance between the gorilla's hands.
Drill two holes near the centre of the beam, and and a hole near each end.
Tie a loop of string through the centre two holes to hang the gorilla up.
Cut another piece of string about four metres long, and thread each end down though the holes in the ends of the beam. You could use two separate pieces, but using one piece removes the chance of knots pulling through holes. To stop the string slipping, I glued and wedged short pieces of bamboo skewer into the holes with the string.
Thread one end of the string through each hand of the gorilla, and then tie a large knot in the end of the string to stop it pulling back through the straw. You could, if you want, add a large bead.
- I made "beads" by cutting short lengths of the corrugated card, gluing along their length and then rolling them around the knotted ends of the string.
Step 7: Climb!
Pull each string in turn (left, right, left, right), and the gorilla will climb the string, legs swinging.
Enjoy!
(Adding the video was gmjhowe's idea)
Step 8: Improvements?
When I first made this, I was planning to somehow disguise the corrugated card. Paint, maybe, or a thin layer of papier mache.
You could do these, of course, but after spending three days looking at his ugly mug, Gorilla kind of grew on me.
I like him the way he is, and I'm not going to change him.
If you, however, make him differently, or make a different animal climb the string, then please post pictures of your creations in the comments. I'd love to see them.
>K<
PS for non-pro members, I have added the PDF to this step.
Finalist in the
Gorilla Glue Cardboard Contest
63 Comments
10 years ago on Introduction
Cool!
11 years ago on Introduction
Thanks Kiteman! I was inspired by your instructable to make a simplified 'Migrating Monarch' toy for a 250+-kids-in-3-hours craft activity. Printed the monarchs that kids colored on stiff cardstock, had them tape the short lengths of straw to the back, used household twine, and a 3-inch length of straw for the top cross bar. They tied knots at the ends of the string, and voilá! Not all of them worked, given the angles and lengths of some of the short straws, but some did and the kids (and grown-ups) loved them!
Reply 11 years ago on Introduction
That's brilliant!
Have you got photos? Or an Instructable?
13 years ago on Introduction
um...can you put the skewer somewhere else?it might be a lil disturbing...
wow perverted a bit?
Reply 13 years ago on Introduction
You, sir, have a mucky mind - that's his navel!
Reply 12 years ago on Introduction
unrelated story time! i used to think that a navel was behind your nose, but now i am wiser and more like Gandalf, so i know better
14 years ago on Step 3
Kiteman typo'd!
Close-up of middle-layer. Notice the hole pierced ijn the legs.
Reply 14 years ago on Step 3
I djon't kjnow wjhat yjou mjean!
Wjait, njor djo Ij. Ij thjink thjat Ij cjan't rjead.
Reply 12 years ago on Step 3
lol
14 years ago on Introduction
the video was very funny I'm amused hehehehe
Excellent. My five year old is most amused. He's now on his second. Well Done.
Reply 14 years ago on Introduction
That's great - how about posting a picture of his work?
I used to have a wooden one of these things in the shape of Humpty Dumpty stuck to the side of my pantry in my kitchen.. Havent seen him since we had the room re-fitted, but i remember him so well from when I was a child! The top beam cant have hung more than 5' off the ground, but I remember thinking how high he got and having to crane my neck to watch him climb to the top! And then the fun little jerky slide back down to the bottom.. Aaaaahhh.. Childhood :D - and i'm only 16 now!
LOL - the simple toys seem to have the greatest impact, don't they?
Well, this is just sickening. Look at all these people worshiping you Kiteman. I mean just look around ........... oops I seem to be standing on the wrong side of the line. Oh dear, I guess it's official - I am also one of the worshipers! Maybe we can form a groupie club and hound you whenever you are online! Drive you crazy by jumping out from behind websites and taking unauthorised screen shots.
Absolutely brilliant Instructable BTW. KarrooWife is seriously ticked off with you 'cause I laughed so hard at myself while practising your self mutilation instructablehttps://www.instructables.com/id/How-to-entertain-small-children-via-the-medium-of-/# in the mirror that I woke the baby!
LOL, thank you for the positivity.
After I posted that video on YouTube, I discovered that there are hundreds just like it...
what did you use to cut the cardboard
A strong craft knife, because scissors squished the corrugations. If I had one, I may have used a coping saw or scroll saw.
