Introduction: Climbing Vine Planter Box
This isa perfect garden box for any type of climbing vine, and is perfect to use as a center piece in your garden.
Step 1: Materials
Four 1" x 6" x 36" boards of wood
Four 1" x 6" x 10" boards of wood
Two 1" x 2" x 60" boards of wood
Half inch steel fabric
1 1/4" wood screws
Two Galvanized Steel Handles
Two Corner Braces
Step 2: Making the Base
Take Two 36 inch boards and screw them together with 10 inch boards too make a rectangle. The 10 inch boars go on the inside of the 36 inch boards. Then screw those two rectangles together with two angled screws.
Step 3: Making the Back
Use the corner braces to attach the 60 inch boards to a 33 inch board going in between. I added an extra screw on the outside of each corner to make it stronger. Then take the steel fabric and cut it to fit the size you would like on the back. Staple it on the wood with a staple gun every 6 inches.
Step 4: Attaching Handles
Attach the galvanized steel handles to the outside of the wood using the screws that it came with. Put handles on each side for easy transportation.
Step 5: Finish the Wood
The final step is to finish the wood using some type of outdoor paint or oil. I used linseed oil. Just pour some on a rag and wipe on every exposed part of the wood. This is to outdoor-proof the wood
