Introduction: Clock Project
We are making a clock out of re-usable objects.We just finished a lesson where we learned about re-using. I chose a piece of wood that was covered in marks to make my clock. Then the piece of wood that otherwise would sit and rot, I re-used.
1 piece of wood
1 clock motor
Step 1: Step 1: Shape Your Piece of Wood
Cut the wood to the size you want it.
Step 2: Step 2: Sand the Wood
Use the sander to make your piece of wood nice and smooth. This will make it look better.
Step 3: Step 3: Inkscape
Use Inkscape to make the hole where your clock motor will fit.
Step 4: Step 4: Get Stuff Cut
Get the clock hole cut and where the motor goes.
Step 5: Step 5: Put Poly On
You should put polyurethane on the clock so it will last longer.
Step 6: Step: 6 Put It Together
You should put the clock motor after the polyurethane dries. Then put the hands on and you are done.
Step 7: Step 7: Present It
You can present your project in a spot that the clock would fit.
