Introduction: Clogged MakerBot Nozzle
If your MakerBot Replicator doesn't produce a good plastic stream in the "load filament" mode, the nozzle may be clogged. A "drooling, thin stream that wraps on the nozzle" is a sign of a partial clog.
What causes a nozzle to clog? In my case, anytime "something happens" and plastic doesn't get pushed through a heated nozzle for an hour or more, I have clog issues. An unlevel platform, dirty drive gear, shrinkage and "upcurl" of a big part can cause the nozzle to quit extruding. If I "walk away" from a 14 hour build, Murphy's Law increases the chances of "no extrusion but the heat's on."
First, open a ticket with MakerBot support. They are excellent and will help you troubleshoot the problem. If the result is "clean the abs plastic out of your nozzle," then you might want to follow these steps.
Materials needed:
Acetone (get this in the "fingernail polish removal" area of a drug store or grocery store)
7 mm wrench
3/16 inch diameter rod
pliers
hex wrench supplied with the Replicator
Step 1:
Safety first. Take your time. There are multiple "heat up" and "cool down" steps involved.
This is no more hazardous than pulling cookies out of an oven--but you wouldn't grab a cookie tray with your bare hands. Don't touch hot parts until they have cooled to room temperature--be patient.
First, unload the filament from the extruders.
Step 2:
Wait until the extruders have cooled to room temperature. Power off.
Unscrew the extruder assembly (two screws) and set it on top of the Replicator. Place the 3/16 inch diameter rod between the extruders.
Step 3:
Turn the Replicator on and use the menu on the front panel to "preheat."
Step 4:
Choose the nozzle (right in this case) and "Start Preheat."
Step 5:
You should see the nozzle heating. When it reaches about 220, you are ready to proceed.
Step 6:
Using the 7mm wrench, remove the nozzle (turn counter clockwise). The nozzle is hot; don't touch the nozzle or the "business end" of the wrench. It should not take much force to free the nozzle.
Step 7:
I use needle nose pliers to complete the removal.
Step 8:
Stop the preheat and let the extruder cool to room temperature. Unless you have a spare nozzle, you can turn the Replicator off, because you will be two or three days clearing up the clog.
Step 9:
Using a glass jar (or something acetone resistant; not plastic) submerge the nozzle in acetone.
Wait 24 hours.
Take a small drill bit (or a toothpick) and pull out as much "mucky plastic" as possible. Do not drill inside the nozzle, just use hand pressure to gently remove plastic.
Soak the nozzle (submerged) for another 24 hours in acetone.
Step 10:
Again, remove gunky plastic with the drill bit. Using a sewing needle, remove plastic and try to get the point of the needle to go through the nozzle hole.
Step 11:
Use magnet wire (#28 or higher, I used #30--found at Radio Shack) to "floss" the point.
You should be able to look through the nozzle and see light. If you don't see a clean "hole," then soak another 24 hours and "floss" again. Don't use floss or string--they might get stuck in the nozzle.
Step 12:
With the extruder cool (room temperature) and the rod in place between the extruders, screw the nozzle in place--finger tight.
Preheat the nozzle to 220 degrees and--using the 7mm wrench--tighten the nozzle in the hot extruder. Don't go macho, this will be 1/16 of a turn or less--you want it secure but not to the point of stripping threads.
Step 13:
Cool down to room temperature. Power off the replicator. Fasten the extruder assembly with the two screws you removed in step #2. Power on and load the filament--it should extrude cleanly.
30 Comments
5 years ago
Did It! I was able to remove the nozzle when it was cool. I used a 7mm socket with a ratchet. There was a little plastic tube that guides the filament into the nozzle. This tube was gunked up inside, not the nozzle itself. Was easy to clean with the smallest hex wrench that came with my creator. I was quite surprised to find this plastic tube sticking inside the upper wide whole of the nozzle. Must be made from some very heat resistant material.
Thanks for the instructions!
5 years ago
Great instructions. This is exactly what I was looking for. However, I'm unable to get the nozzle off!
7 years ago
I'm told the high "E" string from an electric guitar is just the right size to clean out the nozzle. I haven't tried it yet though
8 years ago on Introduction
Why is it important to remove the nozzle while it is hot?
Reply 7 years ago
Solidified plastic will glue the nozzle to the threads. If the plastic is melted you're less likely to break the extruder during the removal
This is based on some instructions that I originally received from MakerBot for exchanging a nozzle--the threads may be damaged if one exerts too much force since the nozzle may be "tight" when cool (or stuck in place with hardened plastic).
You could try to remove it cool, just be gentle . . .
Thanks!
7 years ago on Step 13
Nice write-up.
Might as well clean both while you're at it...
Order two spares and swap them out when there is a problem so you are not down for 2-3 days while you clean the dirty ones.
You may try this also:
https://www.instructables.com/id/Easy-Cleaning-Clogged-3D-Printer-Nozzle/
8 years ago on Step 13
Thanks for the detailed instructions!
Theres a guy on Ebay selling low friction plated MK8 nozzles. They were plated to prevent clogging.
Ebay # 321667110675
Hello,
I tried this method on my Flashforge Creator Pro Dual Extruder on one of the extruders. The nozzle came off, but I haven't been able to put it back on. It doesn't seem to have screw threads like I was expecting, just one notch to catch when it turns, it sort of clicks back in, but when I load filament now, it pushes the whole entry tube and nozzle away from the square taped assembly. Doesn't look like there is broken metal either though. Can anyone offer advice on how these are put back together?
It sounds like maybe your plastic solidified on the threads and needs to be heated up again to screw in your nozzle. Make sure you heat enough to melt the plastic then carefully use needle nose pliers to screw it back in - the threads should be free if it is hot enough.
Thanks. After I took it apart and inspected, and looked at a picture of a replacement nozzle, The nozzle is snapped off and the screw thread is stuck inside the aluminum block. I wonder how I could get it out. I want to replace the nozzle and the heater block, but I'm not sure how to detach the metal filament entry tube from the block.
Excellent instructable, useful for many 3D printers with similar technology. One thing I might suggest is 'rolling' the cooled extrusion between your fingers after you clean and assemble everything, if it is not perfectly round you may still have a blockage or partial clog. A stainless steel 28 gauge hypodermic needle (0.362 mm) can clear some clogs from .4mm nozzles without disassembly, the angled tip can be used to gently scrape out deposits while the hot end is up to temperature.
Why risk damaging the nozzle with a needle? I've never needed to use a needle to clean my nozzle to my printer ever. See my below comment- I hope to save you a nozzle part that can be a bit expensive.
This is a ton of trouble. Easier. Put your nozzle on a stainless steel platform with a small hole in it. Have the nozzle end where it screws in on top of this hole to let it drain the plastic. Now, put this steel platform and the nozzle into an oven. Turn the oven to clean. Let it go through its cycle for a few hours. Let cool (important!). Take out and clean out the ash with some rubbing alcohol. It will tarnish quicker but who cares? I am thinking running magnetic wire, needle etc, could cause the nozzle small end to become scratched easily. and possibly damage it I have done this oven cleaning technique and it works great and keeps your oven clean too! Credit goes to my wife who is a material scientist and runs material through ovens to see what they look like on a daily basis.
Quick question - hopefully not too ridiculous(!) - the purpose of the metal rod? I'm assuming that it is simply to provide counter pressure when loosening the nozzle, correct? Or am I missing something blatantly obvious.... :)
You are correct--without the rod, the "taped square assembly" turns . . . and who knows what problems that might lead to :)
Thanks, Mike...I hadn't considered rotation of the (very technically named) "taped square assembly". :) My initial consideration was rotation of the entire extruder assembly. I may not even use a metal rod given the purpose - it turns out that the handle of my 9mm (metal) wrench slides almost perfectly between the two square assemblies and puts pressure on both.
Out of curiosity, you wouldn't happen to have run across any good places to obtain replacement extruder nozzles, etc.? Since the device is two years old, it doesn't appear to have a direct entry on Maker's support site any longer, and the Maker store really doesn't seem to have anything.
