Introduction: Clone Any Remote Control With Arduino Nano
Clone any Remote control with Arduino Nano
Step 1: IR Receiver Circuit
Components
- Arduino Nano
IR Receiver
- Battery
Connect IR Receiver to pin 11 in Arduino nano
Step 2: IR Receiver Coding
If you didn't found this code in the library , i will upload it here ,
Upload this this code to Arduino Nano , Open serial monitor , press any key in your remote control ,
A code will appear for you, just copy this part of it and keep it
(( unsigned int raw[68] = {9050,4500,600,550,550,550,550,1700,550,600,550,550,600,550,550,600,550,550,550,600,550,1700,550,550,600,1650,600,1650,600,1650,600,550,550,1700,550,600,550,550,550,1700,550,1700,550,1700,600,550,550,550,600,550,550,1700,550,1700,550,600,550,550,600,550,550,1700,550,1700,550,1700,550,};
irsend.sendRaw(raw,68,38); ))
Repeat this step for every button on the remote control until you are sure that you have kept all the code of the buttons you want to copy.
Step 3: IR Rransmitter Circuit Schematic
Make sure to connect IR Transmitter to pin 3 ( PWM ) ,
Components
- Arduino Nano
- IR Transmitter
- Battery
- Push button
Resistors ( 2K for push button - 100Ohm for IR transmitter
Step 4: IR Transmitter Coding
Copy all the codes that you had copied it and put it in here ,
Evey time you will press any key it will send the code to your Tv ... etc
Step 5: Create PCB
Check the connections more than once before connecting the battery or power source ,
I prefer to make a high-quality circuit. I do not prefer the method that I used, but this is what is available to me at the moment .
