Introduction: Close Pin Gun
Step 1: What You Will Need
Two close pins a serrated blade and a tooth pick
Step 2: Gathering the Parts
Take apart one close pin you should have two wooden pieces and one metal piece
Step 3: Making the Gun
Make a slit in one of the wooden pieces
Step 4: Making the Gun Part 2
Put the metal piece on the wooden piece that you put the slit in
Step 5: Making the Gun Part 3
Take the part that you just made and the other close pin that is not taken apart and clamp the other part to the itself go all the way until it can not go any more father
Step 6: Loading the Gun
Take the last wooden piece and use it as a loader and push the metal back into the slot as in the picture then put the tooth pick in between the to wooden pieces as in the picture then pull the metal piece as it fires the tooth pick
