Introduction: Clutch Plate Clock
old car's clutch plate turns into wall clock
Step 1: Parts Required
old clutch plate (I used Maruti Suzuki Swift's clutch plate), numbers for dial, old clock , paints, screws and wooden block to hold the clock.
Step 2: Polishing and Painting
need to remove the rust from a clutch plate and painting
Step 3: Clock Hands
there are two ways to fix the clock hands with clock mechanism one is to increase the axis another one is to bent a hands. I bent it since it's quite easy
Step 4: Fixing the Clock With Clutch
I used super glue to fix it and some small screw to fix the wooden block with clutch plate
Step 5: Paste the Number
once everything is complete use the super glue to fix the numbers. I used only four numbers. 12, 3 , 6 and 9
Step 6: Testing
Make sure that the hands are having proper distance between them so that there won't be any blocking
