Introduction: Cocktail Machine : Smartphone Controlled Arduino/Android
You like technology and party ? This project is made for you !
In this tutorial we will create an automated cocktail machine controlled through an android apps !
Everything for cheap price controlled by arduino
In previous instrucables the cocktail machine was taking a lot of space and could be a bit complicated to make: Here!
Step 1: What We Need:
For this project i will use 8 botlle but you can adapt easily if you want less or more.
-8 channel relay : each channel will be a botlle .(1channel = 1bottle)
-Wire the most important are female to male .
-8 pump the best i found so far.
And that's it, just need to add a box for the machine we will see that in the next step!
Step 2: The Structure
Here you can get the plan to make the machine, the software is solid works , if you are based in france this company does it for a fair price ASTC .
If you found some way to improve it please share it !
Step 3: Mounting
Here you can see the major steps for assemble everything.
There is not much to do , once i got got the case , I put the pump on a wood part then screw on the side (see picture)
I did the same for the arduino and relay i set it on a wood part then screw it on the front of the machine (see picture)
That's it you done for this part !
Step 4: Connecting the Relay/Arduino
Let's have a look how to cable everything:
The first picture show how to connect one water pump.
water pump + = RELAY water pump
Negative - = Charger 12V
I used one charger 12V 0.5A(cut the top) the negative goes to each pump (negative) and positive goes to each channel of the relay .
One charger is enough as only one pump will work at the time
Repeat this for the 8 pump.
Arduino :
Also easy you only need to connect the Digital Output to the relay (see schema) and the bluetooth module.
You can personnalize , for me it's like this :
- whisky DO:5 Relay:5
- Vodka DO:9 Relay:1
- ricard DO:8 Relay:2
- Tequila DO:7 Relay:3
- GIN DO:6 Relay:4
- Orange DO:2 Relay:8
- Water DO:3 Relay:7
- Coc DO:4 Relay:6
Step 5: The Code
Here you have the code for arduino :
So what it does is : when you will send a cocktail from the app it will send a ''number'' to the arduino.
This number is link to a cocktail wich will activate the pump link to it and done !
Important : When you upload the code don't forget to remove the bluetooth module ortherwise it won't work .
<p>char junk;<br>String inputString="";</p><p>void setup() // run once, when the sketch starts
Serial.begin(9600); // set the baud rate to 9600, same should be of your Serial Monitor
pinMode(2, OUTPUT);
digitalWrite(2,HIGH);
pinMode(3, OUTPUT);
digitalWrite(3,HIGH);
pinMode(4, OUTPUT);
digitalWrite(4,HIGH);
pinMode(5, OUTPUT);
digitalWrite(5,HIGH);
pinMode(6, OUTPUT);
digitalWrite(6,HIGH);
pinMode(7, OUTPUT);
digitalWrite(7,HIGH);
pinMode(8, OUTPUT);
digitalWrite(8,HIGH);
pinMode(9, OUTPUT);
digitalWrite(9,HIGH);
}void loop()
if(Serial.available()){
while(Serial.available())
char inChar = (char)Serial.read(); //read the input
inputString += inChar; //make a string of the characters coming on serial
Serial.println(inputString);
while (Serial.available() > 0)
{ junk = Serial.read() ; } // clear the serial buffer
if(inputString == "1"){ //whysky coca
digitalWrite(5, LOW); //whyski
delay(1500); //temps distrib whisky
digitalWrite(5, HIGH);
delay(1500); //
digitalWrite(4, LOW); //coca
delay(3000); //temps distrib coca
digitalWrite(4, HIGH); //
delay(1500);
}else if(inputString == "2"){ //wodka orange
digitalWrite(9, LOW); //wodka
delay(1500);
digitalWrite(9, HIGH);
delay(1500); //
digitalWrite(2, LOW); //orange
delay(3000);
digitalWrite(2, HIGH); //
delay(1500);
}else if(inputString == "3"){ //ricard eau
digitalWrite(8, LOW); //ricard
delay(1500);
digitalWrite(8, HIGH);
delay(1500); //
digitalWrite(3, LOW); //eau
delay(3000);
digitalWrite(3, HIGH); //
delay(1500);
}else if(inputString == "4"){ //COCA
digitalWrite(4, LOW); //COCA
delay(1500);
delay(1500); //
}else if(inputString == "5"){ //whisky gay
digitalWrite(5, LOW); //whysky
delay(1500);
delay(1500); //
delay(3000);
delay(1500);
}else if(inputString == "6"){ //tequila orange
digitalWrite(7, LOW); //tequila
delay(1500);
digitalWrite(7, HIGH);
delay(1500); //
delay(3000);
delay(1500);
}else if(inputString == "7"){ //gin orange
digitalWrite(6, LOW); //gin
delay(1500);
digitalWrite(6, HIGH);
delay(1500); //
delay(3000);
delay(1500);
//shooter
}else if(inputString == "8"){ //whisky
digitalWrite(5, LOW); //whisky
delay(1500);
delay(1500);</p><p> }else if(inputString == "9"){ //wodka
delay(1500);
delay(1500);</p><p> }else if(inputString == "0"){ //tequila
delay(1500);
delay(1500);</p><p> }else if(inputString == "a"){ //gin
delay(1500);
delay(1500);</p><p> }else if(inputString == "b"){ //tgv
delay(500);
delay(1500); //
delay(500);
digitalWrite(6, HIGH); //
delay(1500);
delay(500);
digitalWrite(9, HIGH);</p><p> //soft
}else if(inputString == "c"){ //orange
delay(3000);
digitalWrite(2, HIGH);</p><p> }else if(inputString == "d"){ //eau
delay(3000);
</p><p> }else if(inputString == "e"){ //coca
delay(3000);
digitalWrite(4, HIGH);</p><p> }
inputString = "";
}</p>Step 6: The Android Apps
In order to control our cocktail machine with our phone, we will create an app with MIT app inventor .
Only requirement a gmail acoount. You can upload my app and modify it in the app inventor it is very easy to use but i will advice to check some tutorial before.
To be able to install the app you have to go to your phone setting (in security) allow unknown sources.
Important :
To send value from the bluetooth i used the object "send text" so it will send the number 1 / 2 etc.
You can also use the "send byte number" but it use ASCII so in order to send 1 to the arduino you need to send the value 49 Pay attention to the difference .
Step 7: Conclusion
Here we are just few steps to follow .
The most complicated part would be to create the case that fit your needs mine is a bit bigger than needed but i can stock up some botle .
You can change all the drink i used without changing the code (if you use the same quantity ) , just need to change the picture in the app !
I added Voice recognition in case someone is to "tired" to use the app !
Hope you envoy this instructables please share any idea of improvement for the next version !
