Introduction: Code Block Greek Temple
I'm a teacher an I'm learning use Code Block Thinkercad for my lessons. I decided draw a greek temple after a training on 3D stamp.
To begins coding you have to make one Thinkercad account as teacher or student. You can also create a class for your sudent with an access code.
Step 1: Start
Select new project, Code Block.
Step 2: Column
Draw the first column using forms like cube, cilinder, ring.
Step 3: Columns
Repete the columns using modify and control bar. In this projects there are 13 columns in one side and 6 in the other one.
Step 4: Basement
Using box shape you can draw the basament. You have to try and try to find the right position of blocks.
Step 5: Roof
Draw the roof using the basic form and modify it many times. I put also the text "TEMPIO" in the principal side of the temple.
You can see the .stl file attached here.
