Introduction: Coffee Cup Mug Sleeve Out of Used Cup
I once had a plastic mug sleeve that would turn a coffee cup into a mug, but it was not portable enough and if I lost it I would have to buy a new one! I decided to recycle an old cup and make my own. Plus, for those of you who double cup, you can use this and cut your cup consumption in half!!
Step 1: Supplies
Needed: -Paper cup from your favorite coffee shop, in your usual size.
-Tape
-Scissors
It is important that you use the right size, or it won't work right. You can make more than one and complete the set.
-Tape
-Scissors
Step 2: Cut It Up
Cut it about a centimeter (0.3 inches) from the top. Save this part.
Cut few centimeters (inch or two) from bottom. Keep the middle section.
Keep about 3/4 of the top section.
Fold the middle section and cut along one fold.
Step 3: Rejoin Cut
Spread apart the cut you made by about 3 mm (1/4 inch) and tape it on both sides.
Step 4: The Handle
Now you have to make a handle. You may have figured this out, but the top section is the handle. fold a 1 cm (0.3 inches) on both sides and taper them to the inside of the cup so the middle is on the outside of the cup. Don't tape it on a fold, or you won't be able to put it in your pocket.
The pattern of the mouseover notes on the picture should tell you how to tape it.
Step 5: Slide It on and Enjoy!
Put this on your cup of coffee and you have magically transformed your regular paper cup into a mug! Plus it's cheap and easy to make!
(note: If you laughed at the title of this step, please grow up and get some maturity.)
Please rate and comment!
(Seriously. Ratings and comments are our payment!)
