Introduction: Coffee Maker Arduino
About: Projects made by students in Ms. Lamm's engineering class at Portland High School.
Have you ever wished you didn't have to make you're own coffee? When you get up in the morning, don't you wish the coffee maker would make coffee its self? Well now you can make that happen.
With this simple project, you can turn you're boring old Coffee maker into an automatic one.
Using a light sensor, we will be commanding our Coffee maker to make us Coffee as soon as it senses day light.
All you need is a few supplies, a coffee maker, and some wiring.
For this project you will need the following items:
-Screw Driver
- Coffee Maker
- Alligator clips
- Hot Glue gun
For setting up you're circuit you will need:
- Breadboard
- Arduino
- Relay
- 1k Resistor
- Photo Sensor
- 13 wires
Step 1: Take Apart Coffee Maker
First we will need to connect the Coffee Maker to the Arduino. To be able to do that we also need to take apart the Coffee maker and expose its breadboard. This can be done with a basic screwdriver. Uncrew certain parts of youre coffee maker so that you have access to its breadboard
Step 2: Set Up the Circuit
We will be using a photo sensor to be able to turn on the Coffee Maker using light values. Set up the circuit using the picture attached to this document. Make sure to include a relay, and 100r resistor.
Step 3: Connect Arduino to Coffee Maker
To be able to control the coffee Maker using Arduino, we will need to connect our wires to the coffee Makers power circuit. Find the pin on the breadboard that has power on it, and connect you’re wire to it so then we can control it turning on and off.
Step 4: Reasemble the Coffee Maker
After the whole process of taking apart and wiring the coffee maker, you will need to make it neat and put back together. We had some trouble getting to the breadboard so we decided to superglue parts of the exterior that we had broken off.
Step 5: Finished Product: Code:
int lightpin = A0; //this is the pin that the photo resistor reads
int lightvalue;
int threshold = 700;//if the photo resistor reads this value it will turn on the coffee maker
int CM = 13;//this is the pin for the relay
void setup()
// put your setup code here, to run once:
{ Serial.begin(9600);//tells the serial moniter what frequency to read it at
void loop()
// put your main code here, to run repeatedly:
lightvalue = analogRead(lightpin);//this reads the photo resistor
if (lightvalue>threshold)//this means that if the light value is higher than the threshhold then it will turn on the coffee maker
digitalWrite(CM, HIGH);//this turns on the relay
else
digitalWrite(CM, LOW);//this turns off the relay
Serial.println(lightvalue);//this prints the photo resistor value to the serial monotor
delay(1);//this delays it one milisecond
