Introduction: Coffee Mug Stand
I have make a DYI, Coffee Mug stand, it is a stand that can hold up to four Coffee Mugs. I have made this for the convenience of easy access, storge, and space. Have this stand you will be able to put it any where in the kitchen, such as the counters, table, on shelves, etc. It is basically for if you don't have enough space for coffee mugs in you cabinets or on the counter somewhere.
To be able to make this DIY project you will need:
- 1 in x 12 in Weaber Hardwood Boards
- 4 fl. oz. Wood Glue
- 2 i. x 18-Gauge Brad Nails
- 3.07 in Flat Black Sigle Prong Hook
Step 1: Making the Base
Using the wood that we have got, we will have to cut out a 1in x 8in x 8in plate, after you do that you will then have to cut out another piece of wood. This one is slightly smaller, it is a 1in x 6in x 6in plate. After you cut out both of those you will take the bigger one and put that on a table or where ever you are working, you will then grab the smaller one and put that on top of the bigger one. You will then center the the top piece so that their is about an inch on all 4 sides. You will now grab nails and the nail gun and you will put 4 nails in in each corner of the top plate connecting the top and bottom.
Step 2: Making the Tower
Up next you have to make the Tower of the stand, you will have to get 2 boards cut them both to 14.5in x 1in x 1in. Once you have both of those you will glue them together to make the tower, the measurement should now be 14.5in x 2in x 2in. When the glue dry's you will them grab the base, and find the center of the top and attach the tower with glue. Their should be about 2in of space between the tower and the end on each side.
Step 3: The Hooks
Their are 4 faces to the stand on the first one we want to measure up to 7in and screw in a screw in the center. Go 90 degrees to the left and go up to 11in and screw a screw in the center. Go another 90 degrees to the left and screw in a screw in the center at 7in, and finally go 90 degrees left and screw a screw in the center of 11in.
