Introduction: Coffee River Table
Cheap and simple coffee table inspired by river i've made using hand tools and angle grinder.
Step 1: Choose Wood
You should choose wood that has a bark on both sides.
Step 2: Cutting and Polishing Pieces
Remove with hammer and chisel or spatula, cut wood to square and cut it in half by length with circular saw. Polish cutted woods with angle grinder sanding disc that i used is 80 grit.
Step 3: Connecting Cutted Pieces
Connect pieces of wood with cookie and wood glue. Make a riverbed with angle grinder or router. You can do the riverbed easily with CNC mashine more precisely, i don't haveone, so i used angle grinder and hand tools.
Step 4: Table Legs
Material for legs:
6 pieces of 6mm thick steel rod 70 cm long
4 plates of metal sheet 1 mm thick
8 screws for wood 16mm long
Bend the rods using vice, hammer and you hands.
Weld the bent rods to each other as showed on pictures.Weld metal sheets on end of the rods and connect them with screws to wood.
Step 5: Candle Holder
Build candle holder from piece of wood and glue it to central rod. Secure it with two screws as showed on picture.
Step 6: Cutting Glass for River
Cut your glass carefully, You should first try with scrap glass if you haven't cut glass sheet yet like me, because you'll probably break it. After several failed attempts to cut glass properly i decided to buy transparent acrylic and cut it with jigsaw which is way more easier. You can also do the cut with CNC mashine, or with bandsaw.
Step 7: Apply Blue Film on Cutted Glass
Apply blue (or any other film) film on acrylic sheet, use credit card to even the surface and get rid of air bubbles, and enjoy.
