Introduction: Coffee Table Pallet Project
Check out this fantastic Coffee Table Pallet Project Tutorial today.
This Coffee Table Pallet Project is easy to follow and can be made by virtually anyone. All you need is some nails, paint and pallet boards!
Pallet
Screws / Nails
Paint
Step 1: Mark and Cut the Pallet Boards
Mark the pallet boards ready for cutting
We need the following lengths
  • 2 x 17" inches
  • 2 x 24" inches
Step 2: Make a Rectangle Shape
Attach the 4 boards together with screws or nails to make a rectangle shape
Step 3: Add a Bottom Pallet Board
Attached a pallet board with screws or nails to the bottom of the rectangle shape.
The pallet board should measure 30" inches
Step 4: Attach Supporting Board
You need to attached a supporting board to the bottom board... this needs to be 17" inches high
Use screws / nails to attach the board into position
Step 5: T Shape
Attach a small board to make a T Shape - this board measure approximately 15" inches in length
This board will be used to attach the coffee table top
Step 6: Add Table Top Boards
You need to screw or nail the top boards into position - they are 39.5" inches in length
Screw the board underneath the rectangle shape, but above the "T shape" at the bottom end - this gives the illusion that the coffee table is "floating'
Step 7: Paint
Next you need to paint the boards, you can sand them if you want before painting for a smooth finish. I have left them in a natural state and used Black and White paint.
Step 8: Finished!
You can use your coffee table indoors, in the garden or anywhere you like!
