Cold Smoked Salmon With a Soldering Iron
Intro: Cold Smoked Salmon With a Soldering Iron
My family and I love smoked salmon, but it's pretty expensive at the stores so we don't get it too often. When I was reading through "Charcuterie" (Ruhlman & Polcyn) it had a recipe and I had to try it. But how do you cold smoke without a lot of fancy gear?
To step back a bit, when you hot smoke food you're cooking it at higher temps such as 100C or above. You're adding smoke to the meat, but you're also cooking the food. With smoked salmon you use cold smoking, which is at 37C or below! The fish is cured, smoke flavour is added, but you don't need to cook it with heat. If the temperature gets too high then that will change the texture of the fish. It'll still be delicious, but it's not what we think of as smoked salmon.
Some people come up with contraptions involving a firebox attached to a long hose, and sometimes involving passing the smoke through ice. This tries to make sure that the smoke doesn't get above the 37C barrier. After a bit of thinking I figured out that I could use a soldering iron to get the wood chips to the smoking point without getting fire going.
This recipe happens in parts. First you cure the salmon in the refrigerator for 2-3 days, then you dry it for up to a day, then you smoke it for about 4-6 hours. So depending on how thick the salmon is and how impatient you are, this takes between 3-5 days to make, even though the actual work involved is minimal.
STEP 1: Prepare the Cure
The cure is basically sugar and salt, plus seasonings. The original recipe called for a lot of different things, I've experimented (and so should you!) and this is my "normal" variant.
125g kosher salt
100g white sugar
50g brown sugar
6g pink salt (see note)
Dried dill
Mix it all together in a bowl. That's it.
Note: Pink salt, aka DQ Curing Salt AKA Instacure #1 is a preservative. It's salt and nitrites, dyed pink to avoid it getting confused with other stuff. Since the salmon will be sitting at room temperature while smoking, this is a guard against nasty things growing on it. I'm sure you could do it without, though the stuff is cheap, plentiful, and easy to obtain (I ordered mine online but have later found out you can get it from most butchers that make their own sausage). If you do use it, please make sure to keep the bag sealed and away from kids as in large quantities it's poisonous!
125g kosher salt
100g white sugar
50g brown sugar
Dried dill
STEP 2: Prepare the Salmon
Get a dish about the same size as the salmon. Cover the bottom with about 1/3 of your cure. Put the salmon on top. Pour a bit of rum on top (I've used tequila and vodka in the past, you only need a tablespoon or two to get the cure to adhere to the salmon) and then cover the fish with the rest of the cure. Make sure it's all covered!
Place some plastic wrap over the salmon.
Have a scotch... You're halfway there.
You'll need to gently press down on the salmon as it sits in the fridge. A board, plate, pan, or anything else will do nicely. Put some weight on it. I normally use canned goods, but since I'm submitting this as part of the kitchen power tool challenge I thought I'd amp it up a bit and weight it down with power tools.
Put it in the fridge, it'll sit for 2-3 days. The fish will be firm and you'll see a lot of liquid has left the fish. It's ok to leave the liquid in there while the fish sits, you'll take care of that later.
STEP 3: Make the Smoker
The smoker itself is pretty simple. Take a can, drill a hole in the bottom, and stick a soldering iron in it. Yes, I have a dedicated soldering iron to the cause. Hobby stores sell the same product as a wood burning pencil, usually for cheaper than a soldering iron at an electronics store.
My can looked untreated, but just to be careful I burned the can for a little while.
STEP 4: Rinse and Dry the Salmon
Take the salmon out of the fridge. Rinse it off thoroughly in the sink and place it on a cooling rack. Pat it down with paper towel, then put it in the fridge for 4 - 24h. The surface will get tacky, this will help the smoke adhere.
STEP 5: Smoke!
Now for the fun part. Put your smoker together. I generally use apple wood, it's sold almost everywhere you get BBQ stuff. Fill the can, cover it with some aluminum foil and poke some holes in the top.
The fish goes in your BBQ and the smoker goes below. You don't want the fish on top of the heat source, you want the can to fill the cavity of the BBQ with smoke. If your BBQ has a lot of holes you can cover them up with a towel.
Close the lid, turn on the soldering iron. Shortly smoke should be coming out and will start smelling like awesomeness.
Smoke for 4-6 hours, depending on how smoky you like your food.
Take out and enjoy.
You can keep the fish, wrapped in wax paper, in the fridge for about a week. If it lasts that long!
Take out and enjoy.
10 Comments
wkelly 8 years ago
Once the smoke starts coming out do you turn off the soldering iron? When do you turn it off?
swalberg 8 years ago
wkelly 8 years ago
Cool! Thanks so much. 30W Iron?
Mine says 25W. I don't think an extra 5w will make a difference.
carol.tucker.7509 9 years ago
I may be a bit late on asking this, but do you need to refill the can with woodchips or can you let that sit for a few hours? Is there a preferred method to keep the salmon from resting during that process?
swalberg 9 years ago
With the cans I use I can fill it up with chips and not need to refill. When I check on it I usually give it a bit of a shake with some tongs just to make sure the fresh chips are falling down.
The smoking step is pretty lax. You're not applying any heat to the salmon, you're just exposing it to smoke. So you could put the salmon back in the fridge and start it up later if you needed to, or if the smoke stopped for some reason everything will be fine if you start it up again.
vincent7520 10 years ago
Nice !
Pink salt is not really useful if you wrap the salmon in a plastic wrapping sheet tight enough (it will keep enough of the seasoning ingredients to be properly seasoned).
Also they generally hold the salmon over the smoke (no fire) if it is a a sufficient height (say, 1 meter) : heat has dissipated and will not cook the meat.
Thanks for posting : it's an excellent instructable and the soldering iron idea is worth remembering for other purposes in cooking and eating goodies !…
swalberg 10 years ago
The pink salt is really for the time that the salmon is in the smoker. If there are any microbes on the surface then it's in an ideal environment for them to grow. While it's in the fridge, the growth is slowed (just like if you bought the salmon in the store). To my understanding, wrapping only prevents new stuff from getting on the surface. If there's anything on the surface already it's going to grow and release toxins, wrap or not.
Point well taken on the use of height, though. If you were doing this in any sort of volume that would be the way to do it.
Danger is my middle name 10 years ago
I feel like I'm crazy because I could have sworn I read this before, which is wierd because it's a super specific project. Anyways, great job and thanks for sharing!
