Introduction: Color Projector
This is how you make a colored lamp from household materials
wires
Cardboard
Two AAbateries
Small Light
Aluminum foil
Colored transparent plastic
Electrical tape
Tape
Cardboard
Two AAbateries
Small Light
Aluminum foil
Electrical tape
Tape
Step 1: The Source
First you will want to use the electrical tape to tape the positive and negative ends of two AA batteries together
Step 2: Light It Up
What you need to do is take your small light and attach 2 wires on the positive and negative ends
Step 3: Button
To create the button you will first grab a piece of cardboard twice the length of the desired length of the button, fold the cardboard in half and tape aluminum foil to the 2 sides that touch, make sure that the aluminium foil touch each other when you push down on the top part of cardboard.
Step 4: Circuit
Connect the negative wire to the bottom aluminum foil and a third wire to the top piece of aluminum foil
Step 5: More Circuits
Tape the third wire to the negative end of the battery and the positive wire (white) to the positive end of the battery
Step 6: Color
Tape transparent colored plastic over the light and it will shine that color so you can make a colored lamp
