Introduction: Color Your Desk With LEDs and Hyperion + Arduino Nano
About: I create projects for my videos that I publish on my YouTube channel
🌈Bring your desk to life with a DIY Ambilight system using Arduino Nano, WS2812B LED strips, and Hyperion! This immersive RGB lighting project reacts in real time to what's on your screen. Complete with 3D-printed case, custom wiring, and full setup guide – perfect for makers and gamers!
PROJECT COMPONENTS PART
➡️Amazon Links:
NeoPixel WS2812B LED: https://amzn.to/4i6QUwo
Electrolytic Capacitor 1000uf 35V: https://amzn.to/3yeZoRd
Screw Terminals: https://amzn.to/46mLQQe
Arduino Nano: https://amzn.to/3SqjDT7
Female Pin Strips: https://amzn.to/3SoNmf6
JST Connectors + Pliers: https://amzn.to/3YlF1MN
Perfboard: https://amzn.to/4cVSorr
Various Screws: https://amzn.to/3A9EyDl
Female Jack 5.5x21: https://amzn.to/3SokwLM
LED Connectors: https://amzn.to/4bZPAIS
90° LED Connectors: https://amzn.to/4c0MNPi
➡️AliExpress Links:
NeoPixel WS2812B LED: https://s.click.aliexpress.com/e/_DBCWGlx
Arduino Nano: https://s.click.aliexpress.com/e/_DkniABv
Electrolytic Capacitor: https://s.click.aliexpress.com/e/_DdZM7dp
Connectors for Arduino: https://s.click.aliexpress.com/e/_DDwD1fT
JST Connectors + Pliers: https://s.click.aliexpress.com/e/_DeAV80t
Screw Terminals: https://s.click.aliexpress.com/e/_DlX7Ruz
Perfboard: https://s.click.aliexpress.com/e/_Dk1xwd7
Various Screws: https://s.click.aliexpress.com/e/_DB3BWiH
DC Female Jack 5.5x2.1: https://s.click.aliexpress.com/e/_DB0Ls4F
5V Power Supply: https://s.click.aliexpress.com/e/_DDVvGjR
LED Connectors: https://s.click.aliexpress.com/e/_DnnzQnH
90° LED Connectors: https://s.click.aliexpress.com/e/_DeMkd47
➡️Download File 3D:Makerworld
Step 1: 🛠️Assembling the Board
We'll start by assembling the controller circuit. Use a 30x70 mm perfboard and carefully position your components to fit inside a 3D-printed case. Place the Arduino Nano at the top-left corner and solder it in place. Add a screw terminal, a 1000μF 35V capacitor (bent at 90° to save space), and a JST connector for the LED strip. Make sure to mark polarity on connectors and finalize all solder joints.
Step 2: 🔌Preparing the Power Cable
Let's prepare the power cable: crimp a JST connector at one end, then solder the positive and negative wires to a female DC 5.5 x 2.1 mm connector. Finally, insulate and secure everything neatly using heat shrink tubing.
Step 3: 🧷Securing the Board and Connecting the LED Strip
Secure the board inside the 3D-printed enclosure using two M2x5 screws. Insert the power cable, fasten it to the case using the provided nut, then connect the LED strip to the board. Make sure to use a power supply properly rated for the number of LEDs used.
Step 4: 🖼️Attaching the LED Strips to the Monitor
Place a microfiber cloth on your workbench to protect the screen. Clean the back of the monitor using isopropyl alcohol, especially where you plan to attach the LED strip.
Use angled connectors, apply some solder to the contact points, and temporarily fix them in place with masking tape on the corners of the monitor.
Measure and cut the LED strips along the marked lines. Solder each segment to its corresponding corner, making sure the 5V, GND, and Data lines are correctly aligned. Repeat this process for all four sides of the monitor. Once the frame is complete, peel off the adhesive backing from the LED strips and firmly attach them to the monitor.
Before proceeding to the next step, take note of the number of LEDs on each side of the monitor. This will be useful later during the software setup.
Step 5: 💻Programming the Arduino
Connect the Arduino Nano to the PC via USB and open the Arduino IDE. Copy the sketch from the project’s GitHub and paste it into a new window. Before uploading, install the “FastLED” library by Daniel Garcia. Set:
  1. Total number of LEDs (e.g. 104)
  2. LED strip type (WS2812B)
  3. Data pin (e.g. D6)
  4. Color order (GRB by default)
Select the correct port and upload the sketch.
🌍Scheck Arduino
Step 6: ⚙️Installation of Hyperion
Install Hyperion on your PC. Once installed, access the web interface to configure the LEDtype, number of led, led layout, serial port, and other parameters. You can also calibrate the colors and test effects directly from the panel.
Hyperion Ambient Light documentation
Download Hyperion
Step 7: 🧪Testing and Final Adjustments
Once everything is installed and connected, it's time to fine-tune the visual effects. Through the Hyperion interface, you can:
  1. Adjust brightness and gamma settings for better visual comfort.
  2. Select startup effects and define a default color when the system boots.
  3. Customize inactive effects, choosing a fallback color when Hyperion is not actively syncing with the screen.
  4. Use the LED layout preview to confirm your configuration visually.
Step 8: 💡Final Thoughts
This project offers a great way to add a colorful, dynamic touch to your workspace while learning about Arduino, addressable LEDs, and real-time visual feedback using Hyperion. The assembly process might require some patience, especially when soldering the LED corners, but the end result is visually impressive and highly customizable.
If you enjoyed this project, don't forget to leave a ❤️ — it really helps and is greatly appreciated!
