Introduction: Color Origami Ball
I'm going to show you how to make color origami ball. Actually it's not really a ball but it looks like a ball to me and because I don't know its real name I call it ball.
I made more pictures to show you how to make it. I think they will be enough for you to understand everything!
Good luck!
Step 1: Materials
Before you start you must know that this is a lot of work and you need to be patient. It's going to take a lot of time!
You need:
- 5 sheets of paper A4 from one color ( I choose pink it'll be "outside color")
- 10 sheets of paper A4 from another color ( I choose blue it'll be "inside color")
- a pencil
- glue
- a ruler
- scissors
- and a small sheet of paper with measurement 9 cm x 9 cm ( if you don't have you can make it)
Step 2: Cuting the Parts
Take one sheet of paper ( it doesn't matter the color) and outline the small sheet (9x9 cm I'll call it white square). You must make 6 squares like the white square on one sheet.
In this way make all the other sheets and then cut them. When you finish you must have 30 sheets from the outside color and 60 - from the inside color.
Step 3: Folding the Module
Look at the pictures. I hope you understand everything because my explanations are not very good.
When you finish with the folding module you must have 2 pockets and 2 insertions.
Make all the sheets in that way. This is the part that you'll need a lot of time. You have to fold 90 sheets.
I made a video on how to fold it. I'm sorry for the low quality. i made it with my phone.
Step 4: Glueing
This is a tricky part. Be careful!!!
Step 1. Fist of all we'll make one of the points of our ball. Take 5 sheets from the inside color ( blue) and glue them like this (see the first 6 pictures). Put some glue on the insertion and put it in the pocket.
Make 6 like this! Let's call them "little stars".
Step 2. Then take 5 sheets from the outside color (pink) and glue them with one blue "little star" (see pictures 7 and 8). This will be "star".
Then connect the 5 blue "little stars" with the "star" (see pictures 9-13)
Step 3. Then take 5 pink sheets and connect the blue "little stars" together. When you connecting them carefully try to close the stars. And when you finish you'll have half of our ball. (see pictures 14-18)
Step 4. Then add pink sheets on every corner of the "little stars" which don't have one. You must glue 2 pink sheets on every "little star".( see pictures 19-24)
Step 5. When you finish you'll have one half from the ball and you have to make the other one. Make it with the same way but without step 4 (you won't have pink sheet left).see picture 25
Step 6. When you're ready you have to connect the two halfs.
Step 7. This is easy just glue the left pink sheets from the first half with the blue sheets on the second half. Glue to the same way. see pictures 26-30
Step 5: Done!
Well that's it!
After the glue dry you can open and close the ball. It's nice in the two ways!
Enjoy your new origami ball !!!
The Instructables Book Contest
1 Person Made This Project!
- CrayfishYAY made it!
91 Discussions
9 years ago on Introduction
would it work if i use 4.5cm by 4.5cm paper. please answer!!!!
yeah why not...but I suppose it would be harder to fold...anyway you can still try ;)
once I am done i will post a pic
Reply 2 years ago
when?
thank you
i used 4.5cm by 4.5cm paper too and it's very hard, the folds are small. Good luck if you try
8 years ago on Introduction
people are still looking at this ;)
very good instructable, for the gluing part, it very easy if you use both a video and this instructable, it makes it very easy
Reply 2 years ago
they still are even in 2018
Thank you for your comment :)
5 years ago on Introduction
lindos colores
6 years ago
is there a way to assemble it without glue?
Reply 6 years ago
Mmm no...well I think tape would do the trick.
7 years ago on Step 5
you have done a GREAT job, THANX
7 years ago
This is not origami because you are cutting and gluing
It's not origami but it's Kiragami which includes cutting and gluing.
That is sooo fun!
Thank you for distributing the instructions.
Good luck on future projects.
R306.
Reply 7 years ago on Step 5
Thank you!
8 years ago on Step 4
The PDF file is either not available of the Download button/link is faulty. Kindly advise
why cant i download the pdf file?? please help. thnx :D
