Introduction: Colorduino Scrolling Text: Updated!
In this instructable you're going to learn how to do scrolling text on a RGB LED Matrix using the colorduino board from iTead studios. The colorduino is basically a RGB LED Matrix driver that takes a lot of the work out of driving LED Matrixes. In a combination with different libraries it is really easy to create cool effects and graphics with it. Its an inexpensive project and fun to play around with :).
Step 1: Parts
This project does not require many external components.
Parts List
RGB LED Matrix
- (this is the cheapest and the one I use) Ebay
- (Available from colorduino site) iTead
Colorduino
- iTead
FTDI or Arduino
for programming
- Sparkfun
Jumper Wires
Male to Male
- Australian Robotics
The arduino IDE installed and basic knowledge of uploading sketches.
Step 2: Wiring the Colorduino
The next step is to upload the attached code to the colorduino. To do this you can either use an FTDI adapter or another arduino. Since my FTDI adapter was broken i used my arduino to upload the code. This is good if you want put an Atmega328 chip into a breadboard and be able to program it. This method only works if you have an arduino with a replaceable chip.
1. First step to using the arduino as an FTDI programmer is to take out the Atmega328 Chip
2. Connect the wires as told in the Pin Connections table below
3. Change the board type in the Arduino IDE to: Arduino Duemilanove
4. Change to appropriate serial port
Pin Connections
Colorduino || Arduino
DTR -> Reset
GND -> GND
TXD -> Pin 1
RXD -> Pin 0
VDD -> +5v
Step 3: Programming the Colorduino
Libraries:
In order to achieve scrolling text, two libraries are required. The Scroll library created for this instructable, as well as a modified version of the Colorduino Library by frederickk
Colorduino Library: https://github.com/Electromondo-Coding/Colorduino
Scroll Library: https://github.com/Electromondo-Coding/ColorduinoScrollerLibrary
Installing:
To install the libraries, download the zip of the repo by hovering over the 'Clone/Download' and choosing 'Download Zip'. Then extract the zip in your Arduino's library folder (Documents/Arduino/libraries on Windows). Restart Arduino, and there should be two examples for the Scroll Library.
Step 4: Plugging in the Matrix
To connect the matrix to the colorduino, align pin 1 of the matrix to pin 1 on the colorduino. After plugging it you should see the message scrolling across the display!
Step 5: Demonstration and Final Thoughts
This code is just the start of the possibilities that the colorduino has to offer. You could make interactive displays, display graphics and pictures as well as making signs. Thanks for looking at my tutorial and I hope this has helped you in some way.
123D Circuits Contest
34 Comments
4 months ago
Hello PoisonMondo
Do you have any updated Colorduino Scrolling Text code and library? I can't find anything on the page. Thanks
7 years ago on Introduction
Hi Guys has anyone managed this with more colorduino so that you can have an 8 by 32 matrix ?
I've tested this code with 2 colorduino's to form a 16x8 display. All you need to do is increment the display number value for each colorduino.
EDIT: On the code page, use the download and install the scroll library. Once you install the scroll library, take a look at the example where you will find the displaynumber variable.
Reply 2 years ago
Didn't find the displaynumber variable?
Reply 5 years ago
But does the library handle spanning the displays automatically or does this need to be handled by the user's code?
IE if I want to scan "some example text" across three displays, do I just put a "3" into the displays field and it all starts scrolling at display one and goes across to two and off the edge of three?
Reply 5 years ago
OK, I looked at the scrolltext (which I didn't realize was sample code) and it SEEMS like you just define the number of displays in the line
int displaynumber = 1;
And then the library handles it from there, starting the scroll at the display listed in the "Colorduino.drawChar" line. (display 1 in the sample code)
Is this correct?
Reply 5 years ago
No, this code was written quickly and it has no way of knowing how many displays are connected to each other. You upload the code to each colorduino, incrementing the displaynumber variable for each display
eg.
displaynumber = 1 | colorduino1
displaynumber = 2 | colorduino 2
displaynumber = 3 | colorduino 3
to form a 24x8 display.
Question 2 years ago on Step 2
Can i get a code?
3 years ago
I recorded the "Standalone Scroll" sketch on a Colorduino normally but it shows nothing. Arduino 1.8.5
3 years ago
Hello PoisonMondo!
How to change the font type used in Matrix?
Reply 3 years ago
I have since recreated most of the original functionality of this library. This is now in the master branch of the github repo. Currently it only supports one display, but no longer requires Colorduino_GFX or Adafruit_GFX libraries.
6 years ago
hello, I downloaded libraries.zip & ScrollTextV2.txt, copy libraries to my libraries folder, copy paste ScrollTextv2 to a new sketch. load to board.
I have a text scrolling but is tooooo slooooow and characters are flickering, it takes over a minute to display first "H"
may I do something to correct this (this happend with scroll speed t=200, changing it to smaller values doesn't affect this behavior)
thanks
Reply 3 years ago
Are you using the Arduino IDE 1.0, how did I tell Tachyon?
Reply 4 years ago
Hi, gusantor! Solved your problem? I'm going through the same problem; any tips? Thank you
Reply 6 years ago
I'll take a look shortly
3 years ago
I would sure like to see concise instructions on how to use 2 or 3 displays connected together. Do you program all three with the same code? Do you need different code on each?
Reply 3 years ago
Hi, did you find out yet? If no...
First, install all libraries correctly; Use
the Arduino IDE 1.0
Write the "ScrollTextv2.txtScrollTextv2.txt"
sketch on the first Colorduino by typing 1 in the line "int
displaynumber = 1;" for the first Colorduino. Then, write the same sketch in the second Colorduino, writing 2 in the line "int displaynumber = 1;" and so on successively if you use more Colorduino. After, connect the 2 or 3 Colorduino together and feed the Colorduino's right hand.
5 years ago
As gusantor mentioned, it doesn't work with current versions of Arduino IDE. Can we do something to make this work with current versions of IDE? Or is there a better code available to make this work?
Reply 4 years ago
Hi LakshmananC
I was testing with IDE 1.0.5-r2 and it says: processing.app.debug.RunnerException: Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it;
Would you have any tips? Thank you
