Introduction: Colourful Double Phone Standard
Hello everybody I am Pavezan. If you are different watching a movie with your friend on your phone, and if you want to put your phone straighten that is why I making Colourful Double Phone Standard.
You will need mitre shears, a glue gun, markers, 16 popsicle stick that is the max, paper, and scissors.
Step 1: Step 1
First, colour all the popsicle sticks with your choice, and try it to make it beautiful.
Step 2: Step 2
The first step is to glue the base. Tale 3 popsicle sticks and put them 2 centimetres away from each other. Then take 2 popsicle sticks and glue them to the front of the 3 sticks.
Step 3: Step 3
The next step is to glue on the back support. To do that take 3 popsicle sticks and put them 2 cm away from each other. Then take another popsicle stick and glue it to the top sticks for support.
Step 4: Step 4
The next step is to connect the front supports. Take 3 popsicle sticks and glue them from the bottom of the front stick to the top stick which we glued on to the top back sticks in the last step. Now, are you ready to connect the phone stand?
Step 5: Step 5
The next step is to connect the phone stand. In order to do that you have to make it. To do that take 2 sticks and glue them together from each side. Then put some glue on the stick in the front faces sideways and stick on the popsicle sticks. Then add a stabilizer to the front stick on the bottom so your phone does not fall down when you put your phone on the holder. To do that take a popsicle stick and glue it sideways on the bottom of the front stick.
Step 6: Step 6
The last step is to cut the piece of paper, and then glue the piece of paper on the bottom of your Colourful double phone standard.
Step 7: Conclusion
Now you have a beautiful colourful double phone standard to watch some movies on your phone or giving someone a birthday present. If you need to know how to make a phone standard for yourself or somebody else for some other reason come back and do it over again.
