Introduction: Colourful Rainbow Pillow Case , NATURAL COLORS
This Rainbow pillowcase is a very colorful by using simple products which are available at home by not buying more colours and using whatever available at home home and the natural colours are safe to our skin. I will show simple method to stitch a rainbow pillow case.
I am sure that everyone would definitely try it because I am using whatever is available at home and commonly used .I am not using any artificial dyes.
All you need is a white cloth some Scissors and swing needle and some bread and also turmeric ,baking soda ,Kumkum , or safron, Ujala whitening liquid and any food colouring is acceptable you can also use glass Paints if required.
Step 1: Measuring and Cutting
First of all you have to fold the cloth into two and measure the sides and edges of the pillow you want to use. then you will have to measure on the cloth with the scale and add 2 inches more and mark all the measures. now start cutting it very carefully by adding some paperweight so that the cloth doesn't move.
Step 2: Arrangements
You have to keep aside this cloth and make some arrangements by taking Scissors and some rubber bands and clean floor so that the White cloth doesn't get damp or doesn't get black.
Step 3: Setting the Cloth
After cutting we will get to clothes in the same measurement folded the cloth into two and then cut. Now we have to gently iron the cloth using in iron box to take away all the cramps. Now you have to let it spread on a floor neatly and use some rubber bands to fold it in this way. Do as shown in the pictures.
Step 4: Dye the Cloth
Now take the cloth outside or in a bucket or a tab and be ready to dye the cloth. now you have to take important as shown in the image and mix some turmeric powder with very little amount to 2-3 drops of water. This will give you the yellow colour to your cloth.
Now take the mixture of water and turmeric powder and started pouring on one side of the rubber band tied.
next you have to clean the bottle and add some food colouring here I have used Orange food colouring to get orange colour. You can add 5 ml or 6 ml of water. Shake well and in the cap and then do the same as we have done with turmeric powder.
next I have taken Ujala the whitening liquid and add it to another part of the rubber band tied so it gives purple colour or violet colour to the cloth. remember that I haven't used any water mixing it with Ujala I have directly added Ujala to the cloth.
Next I have used Kumkum aur so called Saffron powder to get red colour hair I have added some Kumkum to the bottle and 3-4 ml of water and added this mixture to the one side of another rubber band.
Then I have used some glass panes to add it pink colour and green colour.
to get blue colour I have used an ink pen and started on the cloth later I did some water and try to spread it and it's a miracle it got spread.
India Dyeing process is done.
Step 5: Sewing
after all the process let the cloth dry removing All the above bands and after its completely dried sew the three edges of the cloth remember not to sew the fourth edge. After all the swing reverse the cloth so that the stitches is not seen and it does not look ugly.
Step 6: Arrangements
gently insert pillow inside the pillow case which we have done to complete the look your I have added some smiley pillows to make it much more colourful.
Your done!!!!!
