Introduction: Colpitts Oscillator, MiniPCB, 06A-20, Rev A1-01
About: I'm Nolan, a circuit design engineer and creator of miniPCBs—small, standardized circuit boards for learning real-world electronics. I design miniPCBs for students, teachers, and hobbyists who want hands-on pr…
I made a Colpitts Oscillator (06A-20) that oscillates at 261 kHz!
I mimicked one of the circuits that's been on Wikipedia since 2009. https://en.wikipedia.org/wiki/Colpitts_oscillator
Step 1: Collect Components
The part number shown in the picture is wrong. The correct part number is 06A-20. This will be corrected in the next revision.
The PCB is a two layer board, and designed to be easy to manufacture and assemble. And it is optimized for cost by being panelized on 100 x 100 mm squares.
Signals are routed on the bottom layer (the layer with the part number), and a common ground plane (as uncut as possible) is on the top layer.
The P1 connector is located in a standard position with respect to the board edges: making it possible to build a universal tester, backplane, or stand.
Step 2: Solder Components
For ease, start with the shortest components.
If a potentiometer is installed with pin 1 in the wrong place, the adjustment procedure will be inverted (CW/CCW).
Step 3: Test With Digilent's Analog Discovery 2/3
Note the outputs are not inverted, and one is stronger than the other. The PCB silkscreen should be updated to only have one output (OUT+).
For ease of changing between five-pin boards, use Interface Board, 00A-12.
