Introduction: Common Base Amplifier, MiniPCB, 04B-060, Rev A1-03
I made a common base amplifier with a gain of approximately 16 at 1 MHz.
Step 1: Collect Components
The PCB is a two layer board, and designed to be easy to manufacture and assemble. And it is optimized for cost by being panelized on 100 x 100 mm squares.
Signals are routed on the bottom layer (the layer with the part number), and a common ground plane (as uncut as possible) is on the top layer.
The P1 connector is located in a standard position with respect to the board edges: making it possible to build a universal tester, backplane, or stand.
Step 2: Solder Components
For ease, start with the shortest components.
If a potentiometer is installed with pin 1 in the wrong place, the adjustment procedure will be inverted (CW/CCW).
Step 3: Test With Digilent's Analog Discovery 2/3
For ease of changing between five-pin boards, use Interface Board, 00A-12.
