Introduction: How to Brighten Dried Leaves and Create a Beautiful Flower Arrangement
Nature gives us thousands of types of trees which have different shapes and textures in their leaves and seeds. when they fall and dry you can create various crafts. I invite you to go for a walk, take fresh air and collect branches, seeds and dry leaves and give them life and shine with tinfoil, a material that almost all of us have in our home.
La naturaleza nos regala miles de tipos de árboles los cuales tienen diferentes formas y texturas en sus hojas y semillas. cuando caen y se secan puedes crear diversas manualidades. te invito a que salgas camines, tomes aire fresco y recolectes ramas, semillas y hojas secas y les des vida y brillo con papel aluminio un material que casi todos tenemos en nuestro hogar.
▪️ tinfoil
▪️ with dried leaves
▪️ branches with dried seeds
▪️ artificial or natural flowers according to your choice
▪️a glass goblet or vase
▪️ hot glue gun
▪️ silicone bars
▪️ glue
▪️ball carving tool
▪️ papel aluminio
▪️ con hojas secas
▪️ ramas con semillas secas
▪️ flores artificiales o naturales según tu eleccion
▪️ una copa de vidrio o un florero
▪️pistola de silicona
▪️barra de silicona
▪️ pegante de cola
▪️un repujador
▪️ hot glue gun
▪️ silicone bars
▪️ glue
▪️ball carving tool
▪️ papel aluminio
▪️ con hojas secas
▪️barra de silicona
▪️ pegante de cola
▪️un repujador
Step 1: We Apply Glue to the Cup
Take the cup or vase of choice and apply glue with a brush
Tome la copa o el florero de elección y aplique con un pincel la cola
Step 2: Measure the Diameter of the Cup
Take the aluminum foil and measure the diameter of the cup, when you have the approximate measurement tear the aluminum foil it does not matter that the edges are imperfect
Coja el papel aluminio y mida el diámetro de la copa,cuando ya tenga la medida aproximada rasgue el papel aluminio no importa que los bordes queden imperfectos
Step 3: Line the Cup
Wrinkle the aluminum foil to be textured then carefully place it by tapping it so that it adheres to the glue and sticks on the glass, line the competent
Arrugar el papel aluminio para quede texturizado luego ir colocándolo con cuidado dando pequeños golpes para que se valla adhiriendo al glue y pegue sobre la copa, forrar la competente
Step 4: Line Branches, Leaves and Seeds
We will continue with the branches with dry leaves and the seeds that we collect
We tear pieces of aluminum and cover the leaves and seeds with the paper
Seguiremos con las ramas con hojas secas y las semillas que recoletamos
Rasgamos pedazos de aluminio y forrarmos las hojas y las semillas con el papel
Step 5: Make a Creeper
Pick some leftover leaves, cover them and create a small vine on the lined cup
Escoger algunas hojas sobrantes, forarlas y crear sobre la copa forrada una pequeña enredadera
Step 6: Make Paper Balls and Glue Them
make balls with the excess aluminum foil and stick on the lined sheets to create some flowers
hacer bolas con el papel aluminio sobrante y pegar sobre las hojas forradas para así crear unas flores
Step 7: It's Time to Decorate
When we have the decorated cup, we will continue placing the branches with the lined leaves, the seeds lined with the aluminum foil and the artificial flowers that we chose
And GUALA we will have a beautiful, bright and striking glass with a raffiant flower arrangement thanks to the shine of the aluminum foil
Cuando ya se tenga la copa decorada, continuaremos colocando las ramas con las hojas forradas, las semillas forradas con el papel aluminio y las flores artificiales que elejimos
Y GUALA tendremos una hermosa, brillante y llamativa copa con un arreglo floral rafiante gracias al brillo del papel alumio
