Introduction: How to Make Lighter With Hotwheels Car
About: Im a Hobbyist, I love to make some fun stuffs and make instructables, Im engineer from Mexico
In this Instructable of ¿COMO SE HACE? I show step by step how to meke an zippo type lighter with recycled material.
My design it´s about a little cannon car and I will add a lighter that simulates a man that will be inside the cannon.
Conventional Lighter
Hotwheels car or any other car toy
Tubes, valves and copper plugs
Zippo wick
Cotton
Lighter Fluid
Sandpaper
Drill
Spray Paint
Supper Glue
Masking tape
Hacksaw
Plumber lighter
solder
Plastic Plug
Cutter
Step 1: Disassemble of the Conventional Lighter
We need to take the conventional lighter "a recycled one" only need to use the little part "flint thumb wheel"
applying force we can pull out this component.
Step 2: Make a Lighter Container With Copper Stuffs
In this point we are going to use the tube, valve and cooper tube to assy the container of the lighter fluid, if we need to modify any spec of the components before the soldering, this is the step.
Step 3: Drill the Cooper Plug
Once our container is mounted in the car toy and the parts are ok, need to make a hole in the cooper plug, this will be the hole where the wick pass through.
the first you need is to mark a point in the cooper plugh then drill it.
Step 4: Soldering of the Copper Stuffs
Now we have all the parts completed to soldering each other
once we solder all part we can sand the part to remove excess solder and no to have problems at moment to paint.
Note: ¡NEED TO BE CARE ABOUT THE LIGHTER AND USE PROTECTION!
Step 5: Dril a Hole in the Hotwheel Car
At this step need to drill our hotwheels car where it will be installed the flint thumb wheel
Step 6: Place Wick, Cotton and Plastic Plug to Container
ALMOST DONE!
Now we need to place the wick with spiral shape inside the container and pass through the hole.
then add some cotton.
Finally close the container with the plastic plug
Step 7: Paint Design
ART DESIGN
In my design i just painted with red and black and added some line design to the container and the car cannon
this is optional you could make your own design if you want.
Step 8: Assembly of All Components
!FINAL STEP¡
With all the part completed we just need to join together each.
take the flint thumb wheel and place in the hole we made in the car.
once we installed, need to join the 2 pieces of the cannon and remove the tape.
With the supper glue we add to the joints of the cannon to the car and flint thumb wheel too, just to ensure do not loose the parts.
¡Now you finished your lighter!
Step 9: ¡Enjoy You Lighter!
Step 10: Step by Step Video in Youtube
in this video from you tube you can see step by step the whole process, my channel is in Spanish but you don´t care this is very explicit.
Follow my channel ;)
https://youtu.be/kwSHaDMbOlU
