Introduction: Compact Lego USB Stick
This design is compact, and differs from the classic Hampton by having the same connective functionality on both sides. If you're lucky with the dimensions of the USB stick as it's also rather easy.
Parts needed:
A standard USB storage stick
A couple of pieces of Lego 3 x 16 x 48*mm
*min, or 1 piece 3 x 16 x 96 mm
And...
A sharp craft-knife
Some good strong glue
Sandpaper
Step 1: Dismantle USB Stick
Make sure you don't have any data on the stick that you can't afford to lose, but they're pretty tough.
Each design will come apart in it's own way, but a sharp knife is all you'll usually need.
Step 2: Hack Lego
The internal lugs were removed (as far as necessary) with a sharp knife.
The PCB was 14 mm wide, a little over the 12.5 mm inner diameter of the Lego piece. I cut channels in one of the halves with a knife to accommodate edges of the PCB, the other half would sit slightly on top of the PCB.
In the previous build (very last pic last step) I just shaved the inner edges of both halves diagonal.
Once both halves were cut & cleaned they were tested together, cut a bit more, scraped a bit and generally refined until the two halves went together nicely.
- The ends were trimmed to length by clamping the two halves together (without the USB device) and sanding them down as a pair.
Step 3: Glue It Together
Once I was sure of the two halves I lightly roughened the two faces with sandpaper, applied a light drizzle of glue (including the filled-in holes) and clamped the two halves together.
Using quick setting 2-part clear epoxy it was set & finished in ~ 5 min
Finished unless you want to add bits to it that is (no glue)
35 Comments
11 years ago on Introduction
Nice
12 years ago on Introduction
here is mine
Reply 12 years ago on Introduction
That's nice, looks very tidy.
L
13 years ago on Introduction
I think that this usb is the best ive ever seen!
13 years ago on Step 3
Nice job.
hello lemonie sorry for not talking reciently i have been board so i have been looking at other things but this one is really nice just as a joke can you make one for me?
Reply 13 years ago on Introduction
I could post you one but it would cost you. Why not make one instead?
L
you wold really make one eventhough i was jokeing?
i can make one i was playing around you know how people joke
I don't know what "people" you're talking about, but that really wasn't funny. No offense...
yes i think lemonie does know how to joke but i dont think you do!
this is a really cool lego usb
posibly the most original
This is COOL! i am going to get some lego and a USB and build myself a Lego USB!! Thanks
bati mani
Where in the world are all of my old legos when I need them...
I love the one with the lego guy on it :D
hey just in time my usb just mysteriously came apart
great ible
If you know what you're doing with knives it's pretty quick & easy - go for it.
L
ive settled for a more industrial look ive got some 3/4 nuts so ill put them round the usb
itle probally be bullet proof when finished
Sounds good, I'd like to see that.
L
you need a cap for it youll think of some thing
